Emergency Brake Light Comes on Intermittently - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 10-10-2009, 07:36 AM   #1
Hello,
Have an issue with the Emergency brake light… it will turn on intermittently for a few seconds as I drive around town but the emergency brake is not engaged. I’ve noticed it turns on only when I make turns or speed up / slow down quickly but it’s not guaranteed to happen everytime… does anyone know what the cause is?
Thanks. Really appreciate you taking your time and sharing your expertise.
4runnerman4 is offline   Reply With Quote
Old 10-10-2009, 07:41 AM   #2
crawlerjunkie's Avatar
Brake fluid level.
crawlerjunkie is offline   Reply With Quote
Old 10-10-2009, 07:42 AM   #3
Team420's Avatar
Maybe try checking your brake fluid level. If it is just above the min line, it will slosh when cornering, and set the light for a sec or 2.
Team420 is offline   Reply With Quote
Old 10-10-2009, 08:17 AM   #4
eddieleephd's Avatar
Quote:
Usually is but if some how that does not fix it test the continuity of the switch open and closed and giggle it when testing. Most likely Fluid but hey some times.
And don't forget to post fix for future readers even if it is embarrassing!!!
I have had my share of Embarrassing fixes!!!
eddieleephd is offline   Reply With Quote
Old 10-10-2009, 11:25 PM   #5
One_96TR4's Avatar
If it's a 5spd the clutch fliud will also set it off.
One_96TR4 is offline   Reply With Quote
Old 10-11-2009, 06:58 AM   #6
When adding the fluid, make sure you go all the way to the max line. Mine was doing the same thing and was only about a 1/4 inch below max.
bootown is offline   Reply With Quote
Old 10-11-2009, 09:06 AM   #7
James Dean's Avatar
If your fluid is low, you also need to check your brakes. The amount of fluid between the max and min is usually equal to the amount of fluid it takes to push the pads or shoes (from new to worn), if you don't have a leak.
James Dean is offline   Reply With Quote
Old 10-14-2009, 08:14 PM   #8
gotta say thanks to the people of the board. simple thing - refilling the brake fluid fixed it up. Thanks!
Brake lights staying on/stuck fountain 86-95 Trucks & 4Runners 5 12-31-2015 07:08 AM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
Dash lights and interior lights wont work ashersullivan88yota 86-95 Trucks & 4Runners 12 07-28-2015 07:22 PM
22re electrical no spark/ no cel /won't start Sandman 86-95 Trucks & 4Runners 8 07-14-2015 01:36 PM
94 pickup no brake lights plz help Johntom240 General Electrical & Lighting Related Topics 7 07-13-2015 01:18 AM
Tags
4runner, auto, brake, clutch, ebrake, emergenc, emergency, engaged, intermittent, intermittently, light, parking, pushing, toyota, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
