drum removal/rear dual wheel
Is there anyone who can help me with some info on how to remove the rear drums on an rear axle 86 dual wheel mini motorhome....do I have to take the axles out of the differential assembly just to get the drums off...I want to inspect my rear brakes. and install a set of mini air bags
If it has the full floating rear axles .
You pull the axles and remove the nuts holding the wheel bearings then slide the drum hub assembly off.
You will most likely have to back the brakes off to get the drums off.
Have new seals just in case.
Not to many of us on here have those axles.
Jcrawl94
10
10-24-2015 04:34 PM
FS[PacSouthWest]: 8-Inch Axle, '97 4R, 4.10, Drum to Drum-Complete
SharpStick
08-29-2015 12:59 PM
crashburnoveride
07-10-2015 06:39 AM
