| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
does the ECT button do anything?
#2 (permalink) |
if i recall, it alters the shift points in your tranny so that they shift at higher RPMs, meaning youre in the power band of your gears for a little longer. that combined with a more lead foot will mean you get a little bit more power.
little fun fact, it stands for "electronic(ally) controlled transmission"
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#3 (permalink) |
While we are on the subject-does it only come on certain models/tranmissions?
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#4 (permalink) |
Not sure of exactly what it's doing in technical terms, but mine has it too and it tightens up your shift points. In other words, it extends the shift points of the transmission so that the engine winds out more between shifts, or in even simpler terms, it waits to shift at higher speeds than it does when the ECT is switched off. Sort of does what you would do when driving aggressively with a manual transmission.
#5 (permalink) |
someone told me that it tells my ecu that my engine is still cold and it dumps more fuel in to it..
#6 (permalink) | |
Quote:
__________________
'99 Taco PreRunner V6 3.4L
#7 (permalink) |
^ Ditto ^
And what's up with calling it the ECT button? The truck has an ECT. But the ECT PWR button puts the ECT into ECT PWR mode
__________________
:Marko: Supercharged 98 4Runner SR5 4x4 3.4L 4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator XM Satellite Radio (Roady 2) :: Autometer Boost Gauge :: Color Keyed Spoiler TOYOTA|moving forward
#8 (permalink) |
ok but what is this???
ECT MOD |
#9 (permalink) | |
Quote:
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures Last edited by drguitarum2005; 01-22-2007 at 07:43 AM. |
#10 (permalink) |
it changes the shift points also its been talked about
#11 (permalink) |
Once agian he is on the money. (its all those school classes. lol)
__________________
-Chris Tread Lightly! 04 Double Cab PreRunner. 3.4 - Auto 84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50 Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris Great Toyota Tech |
#13 (permalink) |
ok so the ECTPWR has nothing to do with a/f mixture...
dose any one still have an active link to the ECT mod??? |
#14 (permalink) |
i think its pretty much mental
__________________
2006 Tacoma 4x4 TRD Sport with 20's and 285 Goodyear Furtura's and 2 inch cornfed lift 2002 Tacoma Extra Cab V6 (SOLD) |
#15 (permalink) |
I realize this is a really old topic BUT... i also wonderd this and used the Search Button but if this is to help it shift in a higher RPM what is O/D For?? Doesnt O/D do that also? So if i used both the effect would be?
__________________
Stock- 1999 4Runner SR5 4WD V6 Stock- 2008 Yamaha YFZ 450 SE |
#16 (permalink) |
O/D is just an extra gear (your 4th gear on the common toyota auto) to lower rpms for high-speed cruisin like on the freeway. it has nothing to do with when your transmission shifts. ECT makes your transmission shift at higher RPMs, thereby letting your engine spend more time in the "performance band" of RPMs, giving you a little improved response and speed.
__________________
#17 (permalink) |
o/d is basically taking a gear away from your tranny, the ect just shifts at higher rpms to give u a better acceleration in all the gears
__________________
1997 Toyota 4x4 SR5 4runner 3.4 auto Front Range Off Road SAS Front: Waggy 44, Chromoly, 4.88, WFO hysteer, Warn Hubs Rear: Taco 8.4, Welded, 4.88 Tube front bumper, TG Rocksliders, 33" BFG All Terrians, Bilstens All around. |
#18 (permalink) | |
Quote:
__________________
#19 (permalink) |
Ok sweet thanks. So if i plan on racing something should i use it?? And according to some topics it increases MPG or Stays the same! So ill just use it all the time. O would it also be Dumb/Smart or normal to use O/D and ECT at the same time?
__________________
#20 (permalink) |
i wouldnt use o/d at higher speeds, but i always have my ect on and the mpg are only affected noticably if ur on the skinny pedal, as opposed to being on it without the ect
__________________
#21 (permalink) |
Alright thanks for the Input!
__________________
#22 (permalink) |
why would you even try to race something in your 4runner?
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Total Chaos Uniball Kit, Fox 2.58'' coilover Shocks, Hannemann Fiberglass Fenders |
#23 (permalink) |
hey i can beat my friends 3.slow lol, and my friends f150 with the 302 but he has some issues lol
__________________
#24 (permalink) |
if youre going to be heavy on the accelerator i would use it, yes. it shouldnt raise gas mileage but i cant argue with the results that some people get so try it out on your own. O/D and ECT have nothing to do with each other. your 4runner has O/D ON normally meaning your transmission can shift into 4th gear. when you press the O/D button, you essentially lock out your 4th gear. ECT just changes the shift points. you can use neither, one, or both at the same time, it doesn't matter.
__________________
#25 (permalink) |
And this whole time I thought it was a stock NOS system on my truck!
I beat four Bugatti Veyrons the other day... Fo shizzle.
__________________
CJ ...<>< 03 DC TRD Tacoma 4wd with a bunch of junk. SOLD 1964 Chevy Biscayne, 230 I6, lowered, satin black, old-school legit. Just wheel the stupid thing!!! But do it responsibly, ok? My band: Road Worn Saints |
| Tags |
| ectpwr |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| nelp with ect button | traveler727 | Newbie Tech Section | 13 | 03-15-2007 06:44 PM |
| how to test ect button? | itsmeagain5789 | 86-95 Trucks & 4Runners | 9 | 02-09-2007 07:15 PM |
| ect button | Jay1 | Newbie Tech Section | 14 | 12-29-2006 10:19 PM |
| ECT button | 881stGenRunner | 84-85 Trucks & 4Runners | 3 | 03-29-2006 04:43 PM |
| what does the ECT button do? | 994runnerguy | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 08-18-2004 06:17 PM |
