damper removal on truck
anyone have a simple way of holding the motor from turning while removing the dampener? Not really wanting to take the starter off to play with flywheel. I tried putting it in 2nd gear with parking brake on and it crawled over the two by four I put in front of the tire.
Not removing the oil pan. Found the dampener is rotated over a quarter turn and need to remove to replace the key and reinstall. I was thinking of putting a bar through the yoke of the transmission. Will try tomorrow.
I always remove the radiator and use a impact .
I did make a plate that bolted to the 4 M8 bolt holes hole in the center that allowed access for the socket
This had a handle on to hold or brace while torquing the bolt
I hope your key way in the crank is not worn to large to keep it from working
Ok, got it off easily by using a bar in the tranny yoke. The problem isn't the key. The dampener pulley seems to be screwed up. The timing notch and the keyway do not line up. They are about 90 degrees off. Is this a sign of a bad dampener or an incorrect part? When the keyway is at 12 o'clock, the timing notch is at 9 o'clock approximately.
I have heard people say that they can slip but never seen pics of it. Make sure when you put it back together that the crank keyway and the cam sprocket are both at 12 o'clock and number 1 cylinder is at TDC on the compression stroke (if the cap and rotor are installed the rotor points to where the number 1 plug wire goes. About 10:30 I think).
The motor was running when I took the dampener off so I know the cam is timed correctly. I only took it off because I couldn't time it with a timing light and it was missing pretty bad. I can't see any evidence that the thing has revolved 270 degrees while staying basically flush inside and out and no signs of tearing of the rubber. That's why I questioned weather it belonged to this engine. The engine is newly rebuilt from somewhere in Nevada. It has a warranty so I'll try to get them to supply a replacement part. Thanks for your comments, well some of them.
Let us know what you find please.
after further inspection, I noticed these two indentations that correspond to the bolt holes for the puller. I am now confident in saying this damper has rotated at some point as the dents don't line up with the holes anymore.
