| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Couple Newbie Q's....
#2 (permalink) | ||
NOTE: this appears to be an 84 or 85 SFA truck, not 86+ IFS...
Perhaps, but it's going to DRAMATICALLY increase fender rub issues. I'm not quite sure how you're hitting the pitman arm though - pix? Quote:
Quote:
Driveshafts should be fine, as will the steering, although now would be the time to look at converting to high-steer.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action Last edited by tc; 11-05-2009 at 03:04 PM. Reason: saw it was SFA not IFS |
#3 (permalink) |
Hey thanks for the quick response.
I was looking at the complete 3rds and this may sound stupid but for instance on marlin crawler, they have a complete 3rd with lock right locker for $800. Is this just for the rear or is that for front and rear? |
#4 (permalink) |
Just one - it will work in either the front or rear on your truck
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#5 (permalink) |
Wow, you look high for having no lift. I guess it's those sweet tires. W/ the 4 cyl, I would go 5.29s, but it depends on how much freeway driving you do. Your rpms will be higher.
I think $800 is pretty good if the Marlin comes set up w/ the gear ratio of your choice.
__________________
97 4Runner SR5 3.4L 4x4 305/70R16 Mastercraft M/Ts on black stock 6 spokes 2.5" suspension lift ARB Bullbar ARB rear locker 4.88s Factory wood grain dash My 4th Toyota truck "If guns kill people, then pens write novels." |
#6 (permalink) |
I can't really afford 2 3rd members so if I just bought a rear third with 4.88 and a locker would I be ok if I just regeared the front?so locker in the rear and open in the front but same gear ratios?and I do a bit of high speed driving so I settled on 4.88s
#7 (permalink) |
You'll be fine, you just can't use 4x4 until you re-gear the front or you'll blow up your t-case.
__________________
#8 (permalink) | |
Quote:
That will certainly work! Just one locker will make a huge difference!
__________________
90 3vze 4x4 runner mostly stock. custom isr mod, cherry bomb turbo muffler 31x10.5 Coursers with stock 4.10s hehe. custom 4runner a$$ sag :( and 1 extremely dirty lebra. (no hood scoops) |
#9 (permalink) |
Thanks for all the replies!
So if i buy the 3rd member from marlin its pretty much a BOLT on install? And also for regearing the front: I cannot find anybody local that installs them!I need some help. And if i send it to zuk at gear installs how much would that cost me? Thanks Again! |
#10 (permalink) |
Yes, replacing a third member is pretty much bolt on. You'll likely need to bleed and adjust the brakes, but otherwise "installation is the reverse of disassembly"
__________________
