| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Couple Lift questions
__________________
<>< 98 Taco 5" lift, ARB Bumper, 33's, Locker, XRC8 Winch, ect. 97 4Runner Limited, Locker, grill guard, clear corners. 4 SALE ~ Lots of Tacoma and 4Runner parts. http://www.yotatech.com/f109/1995-5-.../#post51291818 ~ FOR SALE Pics of my truck |
#2 (permalink) |
Super Moderator-Sponsoring Member
Staff
Check out my website for options.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 "Yeah I own a Jeep, it's PINK and my 2 year old wheels the bleep out of it." |
#3 (permalink) |
Yea wab has a lift that could do you well.
Seriously though theres tons of info if you take some time and read..
__________________
No, I will not be your friend. |
#4 (permalink) |
ok one more question. w/ a 3" lift should i get a diff drop? i understand it helps the drive line angles but isn't it good to have your diff higher off the ground away from rocks?
__________________
#5 (permalink) |
If you are really in the rocks alot, I would invest in some well built skidplating anyway.
__________________
1992 4Runner, 3.0 V6, 5 spd, 33X10.5 BFG MTs, Cragar Soft 8s, no lift |
#6 (permalink) |
wab, do your front lifts compress the coil spring?
__________________
#7 (permalink) |
so i got coil spacers and put um on... and i noticed when the truck was jacked up the wheel is actually being held up by the brake line, does this mean i need to get longer lines? i'm guessing thats what i need i'm just supprised it doesnt tell you in the lift instruction that you need um... seems kinda important.
__________________
#8 (permalink) |
ok another question, it said to get longer shocks, so i got SkyJacker Nitro 8000's, not with truck on flat ground they are almost the whole way in, like maybe could compress anothe 3" max... do i need to get shorter shocks? also i only got about 1 1/2" of lift in the rear so should i just maybe do 1" shims? would that help? one more thing. the springs are now flat, not bowed down... maybe thats how they have been... didn't really look before but shouldn't they be bowed down? maybe i need new springs but i didn't think a 98 would sag that much... any ideas would be great. Thanks
__________________
#9 (permalink) |
Pretty sure you're going to want to extend all your brake lines or you might find yourself unable to stop soon!
#10 (permalink) |
best place to get them? best brand?
__________________
#11 (permalink) |
ok 2 more questions. With the lift an the new rear shocks, the shocks are compresed to about 2-3" of the max, ie a load that made the truck squat 3" would compress the shocks all the way, should i get shorter shocks?
also the lift leaveled the truck, i kinda liked it with the rear a little higher, can i just add a 1 1/2" block? will that interfear with the parking brake cable? anyother ideas? Thanks.
__________________
#12 (permalink) | ||
Quote:
Quote:
- http://www.4crawler.com/4x4/ForSale/...mTaperedBlocks And you can extend the e-brake levers if needed: - http://www.4crawler.com/4x4/ForSale/...rakeExtensions
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#13 (permalink) |
than will i need to addjust the cable after extending the lever?
__________________
#14 (permalink) |
Maybe, maybe not. Depends on how close your adjustment is to the end of travel before you put them on.
__________________
#15 (permalink) |
ok, also i will need longer u bolts and an angled block to keep the drive shaft in line, right? i see that your prices very, how much would it be for what i need to lift it 1 1/2"? thanks for your help.
__________________
#16 (permalink) |
Likely no pinion angle correction needed unless it is currently off or you have swapped in a CV driveshaft in back (or are running a 2-piece/center bearing shaft):
- http://www.4crawler.com/4x4/CheapTri...FixingProblems Block options below: - http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ14 - http://www.4crawler.com/4x4/ForSale/...mTaperedBlocks Price would depend on what width you wanted, 2" or a wider spring-wide block.
__________________
