Cooling Fan
I would like to put it back to stock, the guy I bought it from , wired it through the wiring under dash and I am getting strange thing happing electrically . does any aftermarket place sell the shroud and fan blade for it , I've tried searching but haven't been able to find
I would TRY to go with salvage yard items for this. Maybe get a new OEM Toyota fan clutch.
The electric fans most people put into their cars and trucks are a step down from the factory set up and/or are wired poorly.
SOME manufacturers equipped their heavily optioned vehicles with fans that had more blades and or a stiffer fan clutch. This was usually the case with factory Hi-Performance muscle cars too. I don't know if it's the same with Toyota, somebody told me they are all the same but then I read that the A/C equipped trucks.. maybe 4Runners? also had a front mounted electric fan???
Since you're starting from scratch you might as well check, I sure would.
If the cooling demand is greater just add a non shrouded push fan in front triggered off a simple toggle switch.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
