Old 03-30-2016, 11:10 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Cooling System Guides
Print Wikipost
Coolant Drain plug on 3.4?
Old 10-25-2007, 08:31 PM
kkim's Avatar
Can anyone point out to me where on the engine block the coolant drain plug is located on a 97 Tacoma 3.4l? I can't for the life of me find the damn thing and would like to do a complete flush of my cooling system.
Thanks
Old 10-25-2007, 08:34 PM
fillsrunner4's Avatar
you mean on the radiator? if not you could always take out thermostat and drain more there. i think thats the lowest spot the coolant goes
Old 10-25-2007, 09:05 PM
kkim's Avatar
No, I mean on the engine block. FSM shows a coolant drain on the radiator and one on the engine block on the passenger side. Can't locate it.
I will be changing the t-stat, so maybe I'll just drain it from there, but why is it so difficult to locate the engine block drain?
Old 10-25-2007, 09:31 PM
not sure ive never really seen a plug on the 3.4 pass side then again i havent looked for one
Old 10-25-2007, 10:01 PM
kkim's Avatar
thanks... found the answer on another forum.
http://tacomaterritory.com/forum/showthread.php?t=79291
Old 10-26-2007, 12:44 PM
mt_goat's Avatar
Here's a better pic of one. This is on a 2001 Taco, see the red arrow behind the motor mount:
Note on the 3.4 5VZFE there is only one on the passinger side, removing the thermostat drains the drivers side of the block.
Old 10-26-2007, 12:57 PM
kkim's Avatar
Thank you! That is very helpful.
the1998sr5
15
07-14-2020 08:35 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
kcaudill
07-20-2015 12:06 PM
daddio
07-18-2015 10:20 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: Coolant Drain plug on 3.4?
