| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Clutch/flywheel question
#2 (permalink) | |
Quote:
Fred |
#3 (permalink) |
Fred. What is illegal about what he wants to do?
not trying to be a jerk or anything, but an honest question.
__________________
"alot" is not a word. it's "a lot" get it right |
#4 (permalink) |
Please tell me what he is doing that is illegal. I would really like to know.
Im assuming you are running a 22re (or possibly a 22r), what transmission though?
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#5 (permalink) |
I'd be curious what's illegal as well.?
__________________
89 Pickup, 22RE, 5 spd, 175XXX |
#6 (permalink) |
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
Yeah? Its illegal to put the wrong parts on a vehicle?
__________________
'89 Beater Jeep Eater in progress 4.88's, TRD e-locker, Dual Cases, 33's, Armored, Tread Lightly Mixchallenge.info |
#7 (permalink) |
#8 (permalink) |
Huh...never new that, sorta makes sense though, but does it matter if its the same engine?
__________________
#9 (permalink) | |
Quote:
If you think about it for more than a nano second or two, you'll realize that the emission on the '94 engine is a lot less than that on the older one. Fred |
#10 (permalink) |
Does that make it a state by state law? Vt doesn't test emissions upon inspection (at least on my 89)
__________________
89 Pickup, 22RE, 5 spd, 175XXX Last edited by crews462; 07-02-2008 at 07:04 PM. |
#11 (permalink) |
#12 (permalink) |
thanks fred
__________________
#13 (permalink) |
I as well thought that was a state by state law. I am also not worried though because my dad does NY state inspections for me and at the same time on the 94 it is just a safety inspection so they only check out lights, brakes and whatnot. So thank you for the warning, and Ill watch my back for the legal problems I may run into.
Back to the original issue, it is a 22re motor, I just looked at the old and new flywheel side by side and did not see any real difference, Im going to examine the clutch and flywheel tonight, what should I look for in order to tell if they are the same or different. Thanks Jeremy |
#14 (permalink) | |
Quote:
Fred |
#15 (permalink) |
I doubt it matters but I am going to use the entire intake from the newer truck anyway, which includes the egr system...
again, I doubt that matters Jeremy |
#16 (permalink) |
a 22re is a 22re there is little to nothing they changed on the blocks the only difference u might have is the vac lines and or some plugs and as far as the clutch and flywheel are concerned im pretty sure its all the same
good luck bro
#17 (permalink) |
thanks, I hope you are right.
Jeremy |
#18 (permalink) |
Fred. How are they able to tell? Do they go off the engine case numbers? As far as i knew, as long as the engine is in the same family. and has the same evap system it should be ok. I would think a 22re swapped with a 22re should be just fine. especially if its an older engine into a newer vehicle, that older/"dirtier" engine is going to be held to the newer/higher/cleaner emissions standard of the newer model vehicle.
again, im no expert on the issue. but i do have a friend who is a certified CA smog tech and i think this might be a question ill ask him.
__________________
#19 (permalink) |
Alot of what we do is not legal. Who cares? The monkeys at the inspection place won't know the difference from a 22re from 87 and a 22re from 94...
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3.4 clutch to 3.0 flywheel? | Mise | 3.4 Swaps | 8 | 07-15-2008 08:24 PM |
| 3.0 clutch/flywheel- 3.4 | Jason4X4 | 3.4 Swaps | 5 | 01-13-2008 08:46 AM |
| Installed a new flywheel and clutch | AH64ID | 86-95 Trucks & 4Runners | 3 | 07-30-2006 05:18 AM |
| clutch/flywheel replacement question | hektikwon | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-10-2005 02:31 PM |
| Flywheel and clutch upgrades | lzyellodog | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-11-2005 06:52 PM |
