chevy rims on a tacoma,wont fit!!! - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-30-2012, 02:53 PM   #1
hey everybody new to site, dont know much about rims and tires, for that matter yota's at all. but here it goes, i bought chevy rims but they dont fit, theres not enough thread so it rubs on the caliber. bought a spacer at 1 1/2 thickness but theres still not enough thread i get about a half a nut on the thread. i think there weld rims 15x8 on a 32x11.50r15lt tire, if that makes any deference any help would be great, thanks
98 tacoma 4x4 5spd
awwboo is offline   Reply With Quote
Old 01-30-2012, 03:15 PM   #2
yotasavg's Avatar
you probably need 16" wheels like it came with stock.... I could be wrong though....
yotasavg is offline   Reply With Quote
Old 01-31-2012, 07:57 AM   #3
mt_goat's Avatar
Google "backspacing and offset" There is more to rim fitting than the bolt circle diameter.
mt_goat is offline   Reply With Quote
Old 01-31-2012, 08:07 AM   #4
bob200587's Avatar
Newbie tech?
bob200587 is offline   Reply With Quote
Old 02-01-2012, 03:00 PM   #5
@ mt goat - thanks, i think ive givin up on spacers and thinking about knocking the studs of the yota and getting longer ones.
@bob - no, just retardted
Old 02-01-2012, 03:22 PM   #6
xxxtreme22r's Avatar
How will longer studs fix your caliper to wheel clearance?
xxxtreme22r is offline   Reply With Quote
Old 02-01-2012, 03:49 PM   #7
@ xtream22r - GOOD QUESTION!!! i dunno its just something that passed my mine thinking of ways to make it work, i was thinking if i got longer studs for the yota i would get more of the nut on but its just going to keep rubbing, i guess i needed the spacer without the extra studs then put longer studs coming from the yota
Old 02-01-2012, 03:54 PM   #8
sebastianholmes's Avatar
what you need is a new set of wheels that fit.
sebastianholmes is offline   Reply With Quote
Old 02-01-2012, 03:55 PM   #9
highonpottery's Avatar
^THIS
BUT...if using a large spacer like this you definitely WANT the kind that has their own, separate studs. Spacer bolts to hub using original studs. Wheel bolts to spacer using the spacer's studs.
highonpottery is offline   Reply With Quote
Old 02-01-2012, 04:00 PM   #10
@ sebastianholmes- thats wut its getting down to i went to one last guy and if this doesnt go, on craigs is were its going to go
@ highonpottery - sorry read to fast, damn well im prepared for w/e comes next
Old 02-01-2012, 04:28 PM   #11
spacers over 2 inches are just dumb and ridiculous. they will make you break so much stuff. the buggy i helped build was running 3 inchers in the front and we busted like 3 knuckles without even wheeling hard. he is getting a double long side fj40 axle built for it now. anyways back on topic. you really do just need to get some new wheels, like someone said above i think you need 16 inch rims to fit.
Old 02-01-2012, 04:39 PM   #12
yea if anything happen ill be on it
Old 02-01-2012, 05:38 PM   #13
93Xtra-Cab's Avatar
Are you sure you're using the correct lug nut for the rim? When I switched to my Outlaw IIs, I had to get acorn lug nuts with the shank on the end (I can't remember what they are called), just like these:
The shank on the end goes between the rim and studs so it is fastened by more than just the little threads on the end. If I knew the exact brand and model of rim, I could look it up, but that's not the case here. Also, someone said this before, but it would help if the spacers you got had their own set of studs instead of trying to cram everything on one set of studs.
Or new rims...that'll work too
93Xtra-Cab is offline   Reply With Quote
Old 02-01-2012, 07:37 PM   #14
peow130's Avatar
Sell the rims and tires, go buy a 16 inch rim like your truck was designed for.
Why re-invent the wheel?
And what's wrong with the rims you currently have?
peow130 is offline   Reply With Quote
Old 02-01-2012, 10:03 PM   #15
ok so what happen was i wanted bigger rims and tires and my friend said i got a pair so i gave him money and he got me wut i needed and he told me they were Chevy rims but they would work, tired and now i have this problem, there nothing wrong with them its just time to upgrade and got all the wrong answers
Painted Rims chukarhunt Tires & Wheels 3 10-17-2016 07:04 PM
2012 Tacoma wheels on a 94? 94yotaMI Tires & Wheels 0 07-21-2015 06:47 AM
What Size Tire/Rim Should I Get? Yotoder865 Tires & Wheels 0 07-09-2015 08:51 PM
speedometer 'freaking out' wilbertd 86-95 Trucks & 4Runners 2 07-06-2015 08:39 AM
Tags
acorn, chevy, cjevy, dont, fit, lug, lugnuts, nuts, rim, rims, special, tacoma, toyota, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
