| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Can't get parking lights to turn on
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5 1978 Camaro Z28, 454 Big Block V8 with a 4 Speed. |
#2 (permalink) |
>.>, so no ideas anybody?
__________________
#3 (permalink) |
take your steering cover off the steering colum and take the light switch apart at the steerin wheel their are copper contacts in their and they get gummed up i had the same problem with mine and now they work fine
#4 (permalink) |
Did you put all your grounds together when you did the blinker mod?
I just did the mod myself and put all the grounds from the blinker,parking light and the new GM socket together and it all works perfect if you forgot to add your parking light ground in line you will end up with no parking lights just a thought
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. Last edited by olharleyman; 11-28-2009 at 12:20 AM. |
#5 (permalink) |
olharley, i'm using the original style light, just setting it so that the blinker ground will go into the hot side of the light and turn it off when the blinker is on. it's the easiest way to do it, lol.
__________________
#6 (permalink) |
okay, well i've got my blinkers working....
HOWEVER i cant get my parking lights to work AT ALL.. blinkers work fine through the GM style blinker/corner light combo.. i even tried just hooking up the old style lights onto the wiring, no dice either.
__________________
| Tags |
| 87, 89, 91, gm, ground, lights, parking, pickup, toyota, truck, turn, wont, work |
