YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > Newbie Tech Section
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-19-2012, 03:13 PM   #1 (permalink)
Personal Sales Rating: (0)
2toys's Avatar
Question can i run my fog lights without a relay
Ive got a set of fog lights that i took off my old truck and i lost the relay for them. i can get them to work without it but im just wondering if there's a safety issue here don't wanna burn down my ride.
2toys is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-19-2012, 03:26 PM   #2 (permalink)
17toyotaman's Avatar
You could if you put a fuse in the wiring to pop so the whole truck doesn't go up in smoke, why not just buy a new relay or get one from a wrecking yard?
__________________
1980 Toyota 4x4 Build Thread
17toyotaman is offline
Old 11-19-2012, 03:42 PM   #3 (permalink)
Threadstarter [OP]
2toys's Avatar
ya ill be running a fuse for sure. your right though i should just go buy a relay to be safe. just being cheap haha!
2toys is offline
Old 11-19-2012, 05:59 PM   #4 (permalink)
Personal Sales Rating: (1)
rokblok's Avatar
I recommend a relay and a fuse. Some fog lights can draw a lot of power depending on wattage. And that current doesn't need to be run everywhere(battery to switch, switch to lights). A relay running heavier(12-10 gauge) wire to the lights, with a 16-14 gauge trigger wire from the switch is the best way to do it. Fused off the battery source lead.
Unless you're running LEDs. I have a couple of Rigid LEDs on my bumper and they come with a harness.
__________________
84 x-tra cab, 4X4, 4"rancho lift, 33X10.50X15 BFG KM2s, 3RZ powerplant w/ LCE Performance Master rebuild kit, 6-shooter knuckles, Hy-steer, blah, blah, blah.... And a Softopper, and.....ARB front bumper, big brake upgrade up front, IFS rear, W56B trans, Marlin 1200lb clutch...
1988 4Runner 3.0(hole in the block), 5-spd, bone stock...
1971 FJ40 all stock...in pieces...in storage...
rokblok is offline
Old 11-19-2012, 08:20 PM   #5 (permalink)
Threadstarter [OP]
2toys's Avatar
thanks for the input guys. it dawned on me that i have a relay sitting beside my house ive got a parts truck. so i pulled out the headlight relay off it and ripped out all the wire that im gonna need too. having a parts truck comes in sooo handy im always taking goodies off that thing. ill get some pics up tomarrow.
2toys is offline
Old 11-21-2012, 09:58 AM   #6 (permalink)
Threadstarter [OP]
2toys's Avatar
Thumbs up
E] Click the image to open in full size.[[new relay in empty location and new fuse in empty location.Click the image to open in full size.[headlight relay wired up. taken from a 92 4runner clipped out the plug also[QUOTE]Click the image to open in full size.[/empty locations i used to put my fog light relay a new fuse
2toys is offline
Old 11-21-2012, 10:24 AM   #7 (permalink)
Threadstarter [OP]
2toys's Avatar
lights all finished im actually glad i threw away that old relay this came out way cleaner than the way it was setup on my other truck. i like things to look stock may take more time but way worth it ill never have to worry about this wiring again.Click the image to open in full size.Click the image to open in full size.
2toys is offline
Old 11-21-2012, 10:26 AM   #8 (permalink)
Red face
As long as you run a heavy enough switch and wire along with the correct fuse for the current draw you will be fine.
But you would need to run all new wire and a new switch.
The wire from stock to the relay just pulls in the relay coil and is not heavy enough to carry the full load. without getting warm.
wyoming9 is offline
Old 11-21-2012, 11:57 AM   #9 (permalink)
Threadstarter [OP]
2toys's Avatar
i used the wires from the stock headlamp setup on the 92 so it should be overkill for these lights. pretty heavy guage much heavier than the wiring that came with the lights.
the wire from relay to switch does not need to be a heavy guage cause the current (for the lights)does not flow through the switch. the switch only turns the heavy current of the lights on when grounded and off when ungrounded.
not sure if the fuse is heavy enough but the headlights run a 10amp for each headlight and these are smaller lights so i figured a 15amp should do it they work great and im not getting any heat and haven't blown the fuse.
2toys is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
16, fog, foglights, free, gage, happen, lead, light, lights, pics, powered, put, relay, relays, run, truck, vbulletin, wire, wiring, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
