| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
| Thread Tools | Search this Thread |
#1 (permalink) | |||||
Build Your Own Junkyard Double Case?
__________________
86 Pickup 4x2, Manual (Sold) 87 Extra Cab Pickup 4x4, Manual (Sold) 93 4Runner 4x4, Manual, 3.4 Swap In progress 90 4Runner 4x4, Manual, Blown 3.0 (Stripping out for parts then to become a trail rig/camping/fun truck) 94 Lexus SC400, 1UZ, magnaflow exhaust, after market headlights, bought for parts for the swap into the 90 4Runner |
#2 (permalink) |
Anyone know? I'm looking for carburated 4 cyl. 4x4 transfer case for the geared version right? Thanks
__________________
#3 (permalink) |
It doesn`t have to be carburated, all transfer cases from 84-88 are geared, EFI included.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#4 (permalink) |
You still need the adapter .
Good Luck!
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
#5 (permalink) |
you need the adapter and two gear driven cases...preferably top shifts, but you can get kits from inchworn, marlin, trail-gear to convert a forward shift to top shift.
Aisin does not make an Dual case adapter, you might be thinking Advance Adapters. edit: more info For dual Cases: You will need: -2 transfer cases, usually Top shift -a Transfer case adapter-21 spline or 23 spline (stronger) -a dual case crossmember -shorten rear driveshaft and lengthen rear shaft -cut a hole in the tunnel floor for the second TC lever Transfer Case Info Transfer Case Rebuilding FSM PDF: http://www.lukemiller.org/toys/1985_...r_case_FSM.pdf Trail-Gears TC Videos: t-case: http://www.trail-gear.com/videos/toy-tcase.wmv Dual case: http://www.trail-gear.com/videos/toydualcase.wmv Transmission and other Transfer case info: http://www.4x4wire.com/toyota/faq/parts/
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others Last edited by ocdropzone; 10-22-2009 at 07:01 PM. |
#6 (permalink) |
Marlin has an adapter to put a gear drive reduction box in front of a chain drive (preTaco) case now.
All the Tacoma adapters go to chain drive cases IIRC.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#7 (permalink) |
Ok. Yes I can buy the double case. But I was wondering if I can make one from the transfer cases I see on CL and the junkyards. Yes Marlin sells the kit with gears in front of the chain driven case but it costs 1,400 dollars. I'm just trying to find spots where I can save more money. If I can't I will find me a gear driven case and buy a marlin kit and make it a double case. And that would be cheaper then the chain driven double case.
__________________
#8 (permalink) | |
Quote:
Got a link for this TC?
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#9 (permalink) |
Nevermind tc, found it and it's for 88 and newer...
__________________
#10 (permalink) | |
Quote:
Thanks I will check these out.
__________________
#11 (permalink) |
MC10 adapter using your existing chain drive case is cheaper than buying the adapters and 2 gear drive cases when I was pricing mine.
I ended up finding a total setup with gear drive cases, 4.7, crossmember, twinsticks, adapters - everything - for cheaper than the adapters were gonna cost me so I went that route. In terms of on-road drivability, the chain drive cases are a significant leap over the gear drive. Hayes - sorry I should have been more specific, it's for the V6 chain drive case.
__________________
#12 (permalink) |
I found a guy with a front axle which I was looking for and then he is throwing in a gear driven case ad a w56 transmission for 250. So going that route thanks guys
__________________
#13 (permalink) |
Good Idea???
Thinking of buying this... Any input. Its off CL from a guy
Includes Trail Tamer 5.0 Gear 23 spline......... New: $400.00, 3K Miles Max Inchworm dual case adapter............. New: $325.00, 3K Miles Max 23 spline input shaft ............... New: $200.00, 3K Miles Max Twin Shifter , top shift case......... New: $149.00, 50 Miles Max (not pictured on the unit) Total: ................... If new would cost: $ 1074 ........... All Parts are USED PLUS: The Front and Rear transfer cases, The cases could use bearings, these sell in the range of $100 - 200 each. Asking Price is $800.00 of best offer. Oh and its supposed to to mate up to a W-56 (thats a 4 cyl trans right) Doesn't really matter to me cause I'm putting a pre runner adapter to mate to my Lexus transmission for my 1uz swap. Thanks
__________________
86 Pickup 4x2, Manual (Sold) 87 Extra Cab Pickup 4x4, Manual (Sold) 93 4Runner 4x4, Manual, 3.4 Swap In progress 90 4Runner 4x4, Manual, Blown 3.0 (Stripping out for parts then to become a trail rig/camping/fun truck) 94 Lexus SC400, 1UZ, magnaflow exhaust, after market headlights, bought for parts for the swap into the 90 4Runner Last edited by yodathespian87; 11-16-2009 at 10:41 PM. |
#14 (permalink) |
anyone?
__________________
#15 (permalink) |
The 5.o gears I haven't heard of. He said that most of the parts are from trail gear and advanced adapters. Anyone know anything about this kind of set up? Yeah or no???
__________________
#16 (permalink) |
You are planning on puttin this on an ifs truck?? locked??
__________________
1987 runner, sas, built housing, rebuilt motor, swapped from auto to manual with dual cases and a twin stick, detroit rear, locked front, home brew front bumper w/ winch, sliders, tg dual crossmember skid plate, 4.88s, 35" km2s, and way too much lift! |
#17 (permalink) |
It's going to be solid axle, with 5.29s ARB locked. With the 1uz powering it all. Just gathering parts for this build. Looking for good deals. And this looks to be a good deal if It will work for my set up. Thanks for the response RunnerBoyy
__________________
#18 (permalink) |
All that stuff minus the lexus motor goes great in a locked IFS truck. Dual cases are my second favorite mod right behind the dual ARB's.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#19 (permalink) | |
Quote:
How are you not grenading shafts?? i couldnt keep ifs shafts in my truck only being locked in the mud, especially dualls on the rocks???
__________________
#20 (permalink) |
But should work fine in a Solid axle truck right?
__________________
#21 (permalink) |
and to answer your question, i wouls show up with 600 cash and see what he says..... Those 5.0 gears have gotten a somewhat bad rep for being weak..... but idk what the truth is in that?
__________________
#22 (permalink) |
yeah, it would be fine.... are you planning for longs??
__________________
#23 (permalink) |
Longs or Dirty 30s.
__________________
#24 (permalink) | |
Quote:
I'm not sure if there is a corelation or not, but I've had great success. Never lost a shaft to anything other than lack of maintenence (let a joint run dry from a torn boot. When it broke, I looked in there, and there was more dirt then grease. Personally I don't count that one, but thats up for interpretation I guess. However, that was before duals). The IFS is a system like anything else, and has its strengths and weaknesses like everything else. I can see why mud would cause you all sorts of problems, as from what I've seen, mud is not something that can be crawled. Also, wheeling in rocks and rock racing are very different animals. The big dollar trucks with the strongest parts on the market, that are usually seen in the vids are hammering down. I very rarely see anything above 1000-1200 RPM's when I'm driving over obstacles, even larger stuff: ![]() And a vid of the same obstacle, which, while clearly shows how poorly I can select a line sometimes, also is representative of my normal throttle usage and speed.
__________________
#25 (permalink) |
Thanks guys. Nice pic by the way. That was the pic with the dove tail I was talking about. Thanks again
__________________
| Tags |
| 93, build, case, cases, double, dual, marlin, parts, putting, speed, tcase, top, toyota, transfer, truck |
