| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Brakes w/ a Weird Noise question
#2 (permalink) |
when you say mushy how far does the pedal travel could it be free play because of slightly less adjustment in the rear brakes. could be a very very small leak in a line somewhere under the truck check around all the brackets holding the line in place they are common for holding moisture and rotting lines slowly. also does the truck have a valve on the rear lines over the rear end to compensate for extra weight?
#3 (permalink) |
Thanks never saw the valve till today. I bled it also. I Bled all four corners with minimal evidence of air and minimal contaminants. It still has more mush to the pedal than I would prefer. When braking it comes within an inch or two of the floor.
I gave the lines a cursory once over and found NO apparent leaks and no real fluid loss. I am leaning now 'twords the vacuum booster itself being sub par. I thought we checked it last time, but it seems like a likely possibility. After bleeding them today they are better but still softer than I want them to be. I remember them being better than they are now after I replaced parts last time. Fluid is in good shape, not dirty so I am leaning twords mechanical ... booster or vacuum line from intake. Thanks for the help though..... I learned something. Last edited by reduxof4runner; 11-07-2009 at 01:08 PM. Reason: typos |
#4 (permalink) | |
For the clunk I'd check that your caliper bolts are there and tight. Also make sure the pins that go through the pads are there. Caliper has to practically spit out a pad for the pistons to come out too far. When they do you will lose lots of brake fluid and it won't stop. Doesn't happen with the Toyota's with pins going through the pads.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
| Tags |
| brakes, making, noises, wierd |
