Blocks for the rear?
Old 09-06-2006, 10:30 AM
CJM
CJM's Avatar
Why would you not want to use blocks in a lift kit? I am looking to lift my t100 and find every kit says it uses rear blocks, but I keep reading everyone says to stay away b/c of axle wrap. What exactly is axle wrap anyways?
Sorry I am such a noob, but I wanna do this right so I'm not stuckon the trail someday with ruined rig.
Old 09-06-2006, 12:05 PM
snap-on's Avatar
just what it sounds liek...
as you accelerate (or break) the rotational force has to be offset by something. (like a tail rotor on a helicopter) this resulting force wants to push the pinnion up/down. If it gets sever enough you can snap U-joints. leads to U-joint missalignment... accessive wear.... vibs....
just overall bad things... you dont want it.
Small 2' long add-a-leafts arnt much better....
Old 09-06-2006, 12:39 PM
CJM
CJM's Avatar
SO what should I use in place of the blocks or the add a leafs? I cant afford a true custom leaf setup like the alcans I read about.
Old 09-06-2006, 03:17 PM
snap-on's Avatar
how much lift?
Old 09-06-2006, 04:35 PM
CJM
CJM's Avatar
About 4", No one makes a anything else. 4" by superlift, procomp and trailmaster are it.
This is one of the last things I wanted to do though-but I wanted to find out the info now as it may change how everything goes:
Plan was to do nerf bars and new bumper/winch (if I can ever find a sheetmetal style tjm/arb), then more agressive tires and a rear locker. The lift was to complete it.
Basically, do like this guy did with his, but use a regular lift kit and not find chevy springs: http://home.4x4wire.com/erik/t100/susplift.htm
Old 09-06-2006, 06:34 PM
Elton's Avatar
this is why blocks are bad https://www.yotatech.com/forums/f116/time-part-her-out-94024/
Old 09-07-2006, 12:28 PM
4Crawler's Avatar
One option is to run the blocks now and then start saving up for a set of real lift springs down the road, if you can't afford them now.
Old 09-07-2006, 04:57 PM
CJM
CJM's Avatar
That could work, I dont plan on doing any rockcrawling or serious 4x4. Just moderate stuff I can do during the weekends.
Old 09-08-2006, 07:31 PM
Sdkfz251/7's Avatar
I got a set of Revtek 3in blocks on my '00 Taco and I really wish I would have just saved up more cash and gone with Skyjacker 2.5'' lifted springs instead. Oh well.
Ryan
Old 09-08-2006, 08:05 PM
Beast's Avatar
I can spot a block lifted truck from a block away and it makes me laugh every time.
If you want a cheap lift go add a leaf or big shackle
Old 09-09-2006, 09:18 PM
Tacoma Dude's Avatar
...or you can just save your money until you can do it right.
Why put your truck at risk just so you can get it lifted sooner? Especially since you know you're going to be putting it to use and not keeping it as a street queen.
kcaudill
07-20-2015 12:06 PM
bigjstang
07-12-2015 12:31 PM
jon.r
07-11-2015 03:34 PM
hangtown88toy
07-10-2015 02:33 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Blocks for the rear?
