ARP studs for 22RE cyl head - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-21-2009, 12:10 PM   #1
mcm375's Avatar
What is the right part #/size stud from ARP for a 22RE cyl head set?
Instead of buying new head bolts I figured I would go to proper studs...
Anyone know of a distributor in the greater Sacramento/El Dorado County, CA area?
EDIT: http://www.summitracing.com/parts/ARP-203-4201/ <-- looks like it, but lists 22R. No diff for 22RE?
mcm375 is offline   Reply With Quote
Old 07-21-2009, 11:29 PM   #2
4Crawler's Avatar
That is what I used on my 22RE:
- http://www.4crawler.com/4x4/CheapTri...l#CylinderHead
I got mine from Summit.
Might try the ARP dealer locator:
- http://www.arp-bolts.com/Dealer/Dealer.html
4Crawler is offline   Reply With Quote
Old 12-18-2012, 09:45 PM   #3
Does anyone know for sure if they are the same part #? Reason I ask on a dead thread is because my block pulled a head stud thread (arp head studs) and I messed the one bolt up and now need a new one however I dont have the part number any longer and see that summit sells them individually. Anyone?
poppypizza is offline   Reply With Quote
Head Gasket job 90 4 runner 3.0 vze 6 point head bolts size? kgcwb44 86-95 Trucks & 4Runners (Build-Up Section) 2 02-28-2016 06:00 AM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
Do I bother fixing it? 1993 3vz-E 4x4 Colington 86-95 Trucks & 4Runners 13 07-21-2015 06:24 PM
'96 3.4L which fan clutch? 1996Taco 95.5-2004 Tacomas & 96-2002 4Runners 3 07-20-2015 01:02 AM
85 22re gas removal and such! HELP! ryerye13 84-85 Trucks & 4Runners 3 07-14-2015 09:27 AM
Tags
2034201, 22, 22r, 22re, arp, bolt, bolts, forum, head, kit, sizes, stud, studs, toyota, toyotas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
