All newbies shall watch this.
Old 01-12-2016, 02:27 PM
  #121
SwVa_1stGen's Avatar
Well that was a new experience
Old 01-15-2016, 09:21 PM
  #122
mike88se's Avatar
Done.
Old 03-30-2016, 05:00 AM
  #123
Rupemaster's Avatar
Loud and clear!! Stickies got me to where I am today...
Old 05-31-2016, 03:59 PM
  #124
X-INMRN's Avatar
Newbie
well now i know my status as a newbie, hopefully i won't be getting called that dumb ass newbie.
Old 06-17-2016, 05:33 PM
  #125
4runnerCal's Avatar
Abide I shall. Yay for newbies.
Old 06-25-2016, 10:40 AM
  #126
DMO2869's Avatar
Sounds do able!!
Old 09-10-2016, 11:53 AM
  #127
skoritz's Avatar
Brilliant.
Old 12-12-2016, 08:41 AM
  #128
Aaron Logan's Avatar
That was good...wish I had this on other boards in the past...
Old 12-15-2016, 06:48 PM
  #129
BayArea_4runner's Avatar
awesome video lol will abide most definitely
Old 01-21-2017, 03:41 AM
  #130
SomedayJ's Avatar
Very funny!
Old 02-14-2017, 03:50 PM
  #131
rocket01's Avatar
Roger that captain
Old 04-14-2017, 01:13 AM
  #132
Mathew C's Avatar
This dude abides... Thanks for the heads up!
Old 05-22-2017, 04:20 PM
  #133
ericwudi0830's Avatar
that was really helpful
Old 05-26-2017, 07:03 PM
  #134
Keith Sawyer's Avatar
Newbee
yup. I'll still screw it up. Hell, I can't even remember my username or password.
Old 06-20-2017, 05:01 PM
  #135
foothillbill's Avatar
Originally Posted by 4-RUNNIN' FREAK
Sounds simple. Now I worry that my computer will sabotage me somehow.
Old 04-05-2018, 04:59 PM
  #136
ORDreamer's Avatar
wish there was a vid like that for more .... still laughing
Old 04-05-2018, 08:57 PM
  #137
Halftrack's Avatar
Howdy all from Nevada. I have come to own an 87 4x4 pickup single cab, 22r motor with what I am beginning to think is a home made dash/ engine/ interior/ wire harness swap. Runs good. I have a strange noise from the transmission. Anyone know any good but reasonably prices transmission mechs in Northern Nevada?
Old 05-27-2018, 05:11 PM
  #138
zerokelvin's Avatar
85 4runner no run condition electrical problem
Hello all,
This is a summary of my other thread trying to track down why my truck isn't running. It will start, run a for a few moments (5 seconds or so) then die. Many suspects have been eliminated so we're focusing on only a few now.
Here's what I (with help from forums, thanks RAD) found and looking for advice on how to fix it.
1. After key returns to ON/RUN position AFTER starting up; truck dies. Getting no spark at this point. Tested plugs and visually confirmed all four are firing on start and if I continuously hold key in start position, even if engine starts... it will continue to run. When key returns to ON/RUN position, test lights go off.
2. Fuel pump AND C.O.R. turn on (COR clicks) when key is turned to the ON/RUN position with engine not running/pre start. I was told that neither of these components should be running, that they only should come on in the START position and/or AFTER
truck has started running (the AFM takes over after start to keep fuel pump and COR powered on and working). If this is incorrect, please explain correct timing and function. i.e. when should pump and COR be powered on by key position.
3. What causes/controls spark to quit after engine starts? What conditions need to be met in order to continue to fire?
More information and tests; All four injectors are working (cleaned, balanced, tested by a professional). Power to injectors during START was confirmed by noid testers on all four. Fuel pressure is measured at 40psi in the ON/RUN key position and drops to 30psi when cranking/starting. Starter, coil, igniter test at 12V with key in ON/RUN position pre start.
Old 06-05-2020, 12:08 PM
  #139
Toyogator00's Avatar
Great video / advice. This newbie shall abide .
JonG85
01-18-2023 04:31 PM
ashamsuddin
17
01-13-2023 03:17 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
93RedKrawler
09-29-2015 02:50 PM
Quick Reply: All newbies shall watch this.
