AC belt/idler pulley 22r
Hi. I am trying to replace an AC belt on a 91, 22r and have a couple of questions. If it is, will that allow the tension to be adjusted. Is the pivot bolt in the center of the idler pulley? And what position should the idler bolt be? Should it be snug to the bracket? Sorry it has been a while since I have had to work on this truck. I have a Haynes manual but it isn't much help. Thank you.
Thank you sir. Should the bolt that runs through the pulley (about 2" long) be tightened up to the bracket. The belt has been off for some time. Thank you.
buckz6319
08-05-2017 03:50 AM
Toys4parts
09-26-2015 01:56 PM
