96 4Runner rear coil & strut replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-28-2009, 02:16 AM   #1 (permalink)
Hey everyone,
I have a 96 4Runner that I have decided to lift. I bought a lift kit from "Revtek". It is an all around 3" lift, spacers. I was able to install the front with no problems, but the rear spacers are giving me trouble.
Problem #1
I have a spring compressor that worked fine on the front coils, but doesn't work on the rear. Is there another way I could compress the rear coils?
Problem #2
I am also installing new bilstein struts, and again the fronts were very easy to change, but I can't seem to understand how to remove the top nut. There just isn't enough room to work. Any idea's?
amoskalets is offline
Old 10-28-2009, 06:09 AM   #2 (permalink)
Smallwood0507's Avatar
I cant help you much on the springs but for the rear shocks their a pain in the ass. What you want to do to get the old ones off is to jam a wrench up their against anything you can and twist the body of the shock to get it off....but of course (i used bils as well) you cant do that with them. You have to jam an alan wrench against the side then acting like gumby get another wrench up their and twist it as tight as you can before you snap...for the driver side rear shock you will need to drop the spare tire and reach through the car....make sure to take deep breaths soo you dont get pissed off......good luck
Smallwood0507 is offline
Old 10-28-2009, 07:03 AM   #3 (permalink)
What coils are you installing in the rear? I did not need coil compressors for the rear when I replaced mine with OME 890s. I just let the axle droop down all of the way and applied a little bit of additional pressure on the side that you will be removing/installing first.
__________________
99 Limited
98srx6 is offline
Old 10-28-2009, 06:22 PM   #4 (permalink)
Smallwood0507,
Thanks that helped I was able to replace the driver side Strut, but the passenger side strut doesn't want to budge. I'm almost tempted to drill a small hole from the trunk space and get an air gun in there. I'll just keep trying I guess.
98srx6,
I'm not replacing my coils, I'm adding spacers to them. Basically I need the coil compressed about 3" in order to slide the spacer in. What I did was I went to sears and bought a "Hook" spring compressor which did the job.
Old 10-28-2009, 06:33 PM   #5 (permalink)
dannomite's Avatar
If you are replacing the rear shocks then just cut the shock shafts. If you are reusing them then spray the crap out of them with some penetrating lube and let it sit for a bit. I was able to get in there with a pivoting head ratchet and get a fair bit of torque on the nut. Also if you take the time and search you will find several threads about this very procedure.
__________________
1996 SR5 5speed rear locker.
dannomite is offline
Old 10-28-2009, 08:38 PM   #6 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
the rear isn't to bad just undo the shocks rear panhard bar and sway bar end links
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is online now
Old 10-29-2009, 05:03 PM   #7 (permalink)
Sweet thanks a bunch guys, Saturday it should be done.
Tags
4runner, 96, coil, kit, lift, problem, rear, removing, replace, shock, spacers, springs, strute, struts, toyota, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
