93 4x4 pickup w/ slight clunk under drivers side floorboard - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-27-2008, 03:43 PM   #1 (permalink)
I have a 93 xtra cab Pickup 4x4 5spd w/ manual locking hubs that is making a clunk under the driver side floorboard.
When in 4x4 high & low , it makes the clunk, 4x2 with hubs in and with hubs out it makes the clunk.
With the wheel turned lock to lock in either direction, it does not make a clunk.
The only time it does not make the clunk is in reverse.
It is very slight, if the radio is on, I can't hear it, but I can feel it. It on is a clunk for the first 1/4 rotation of the tire.
Any ideas what it could be? I thought it might have been a u-joint or a cv-joint, but with the hubs out, it still makes the sound.
Recent front end work includes the 50n recall 10K miles ago, new front shocks, wheel bearing repack, and rotor resurfacing.
I'd like to figure this out before it becomes a very loud expensive clunk.
It almost sounds like something is binding upfront.
b1gmoose is offline
Old 01-27-2008, 08:44 PM   #2 (permalink)
bigarms23's Avatar
sounds like you need a new hub and the sound will go away
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1972 stepside jimmy d44/d70 425hp
1995 green range rover
bigarms23 is offline
Old 01-28-2008, 08:37 AM   #3 (permalink)
22RE_yota's Avatar
So just to be clear, the clunk happens with the hubs locked in 2wd. and in 4wd High and Low? **EX: the clunk doesnt happen in 2wd with the hubs Free.
Mine may have the same problem, and if so, I can give you a direction to follow.
__________________
FOR SALE:1991 Toyoya pickup 4X4, Grenade Green/grey. Reg. cab & long box, 22RE & 5spd. Original 181345kms!
Other stuff:
-LC Engineering Header
-Downey Off road cold air intake
-KYB MonoMax Shocks
-31x10.5x15 BFG All Terrains
-AISIN manual hubs
-Factory Box Liner
NEW TRUCK!
2003 Taco 4x4, silver/grey. Extened cab. 2.7L, 5spd.
Bone Stock! With 31523Miles
22RE_yota is offline
Old 01-28-2008, 09:04 AM   #4 (permalink)
'884Runner's Avatar
Sorry, I thought it was something transfer case related, but it does do it in 2wd. Nevermind.
'884Runner is offline
Old 01-28-2008, 09:44 PM   #5 (permalink)
22RE_yota's Avatar
My truck only clunks randomly when the hubs are locked in 2wd, I guess when the hubs are locked in 4wd it dose it randomly too, I was told to replace the bronze bushings for the CV shaft in the front wheel spindle. I have heard that Upgrade kits are also avail to make them roller bearings instead. look to see if there is alota slop between the spindle shaft aqnd the bushing, I dunno the tolerence and it wont tell you much in a clymer manual either, maybe someone else could help us out?
__________________
Other stuff:
-KYB MonoMax Shocks
-AISIN manual hubs
-Factory Box Liner
NEW TRUCK!
Old 01-29-2008, 06:28 AM   #6 (permalink)
The clunk / binding noise happens when the the hubs are locked and unlocked. It does not make a difference if the transfercase is in 4x4 or 4x2.
So that pretty much rules out the u-joints & cv-shafts since they don't spin in 4x2 w/ the hubs unlocked. Correct??
It's not random. It happens every time when starting from a dead stop. But it does not happen in reverse from a dead stop.
I cleaned the hubs & repacked the wheel bearings 10K miles ago when the 50n recall was done. All parts were torqued to spec & I used a 54mm socket & not a chisel/screwdriver to set the pre-load.
Could it be a possible ball joint? I know the boot was ripped on the drivers side UCA and I've been driving quite a bit on sandy salty roads for the last 10K miles.
Thanks for the replies. Any other ideas?
I can feel it sort of rattle/clunk over bumps in 1st & 2nd under 10 miles per hour.
The passenger side is fine.
b1gmoose is offline
Old 01-29-2008, 10:16 AM   #7 (permalink)
22RE_yota's Avatar
hmmm, sounds similar to my issue, but not entirely. When you are letting the clutch out (like when its almost at full travel of its release) does it make the noise then and every time you shift? or just in first when you are taking off. I think you may be onto something with the ripped ball joint. if you have time pop it off/ or inspect it for unusual play or if you can feel a worn spot. Also check your torsion bar bushings and the stabilizer bar bushings aswell.
__________________
Other stuff:
-KYB MonoMax Shocks
-AISIN manual hubs
-Factory Box Liner
NEW TRUCK!
Old 01-30-2008, 12:45 PM   #8 (permalink)
Yes, the sound is made near the top / end of clutch travel, just as the vehicle is moving forward. It will do it into 2nd gear sometimes with a clunk as I relase the clutch.
I'll look at the torsion bars & busings, but those have been pretty much rusted and will stay that way until they break.
No sense in trying to take the ball joint out unless I have a replacement for it. It looks like the bolts are pretty rusted & might need a little extra assistance when being removed.
I'll keep driving it, I'm putting on about 700 miles a week right now, so I'll know when the sound gets worse & if it gets to the point when I can't drive it, I'll have to fix it.
Thanks for the reply. I'll wash the truck tomorrow so I can inspect the bushings.
~ryan
b1gmoose is offline
Old 02-04-2008, 10:46 AM   #9 (permalink)
22RE_yota's Avatar
ok I looked into my truck a bit more, now that I had time, the primary issue is the at I have squeaky steering knuckle bushings.-those infamous brass bushings, there is a thread on how to make your own bushing greaser tool, i takes a lil welding and some machine shop basics to do it, but when you have one, you'll be the king of yotas between your buddies. look it up in the newb sect, or 85-95 trucks.
There is a clunk when driving and shifting a little prematurely. i notice it is very slight in every gear, but is more noticeable when luggin a taller gear. that seems to me as normal, but I havent heard your sound so it may be something as simple as this.
You are correct it isnt your cv's or any of that, but most likely I would bet money on your wheel bearings or those brass bushings.
I have bought and sadly cant return them, so I plan on making a grease tool for these and replacing them in the spring. oh and when taking apart the wheel bearings, be sure to use a 54mm socket to save you some greif. some people like to use the hammer and big screwdrider technique...I've done it myself and am not proud of it. you could proly get a 3/4" drive 54mm socket for $20 or under and an adapter to 1/2" for a reasonable dollar too. good luck hope this helps.
__________________
Other stuff:
-KYB MonoMax Shocks
-AISIN manual hubs
-Factory Box Liner
NEW TRUCK!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Strange sound near passenger side floorboard 4runnin2 95.5-2004 Tacomas & 96-2002 4Runners 3 10-12-2007 05:55 PM
clunk, clunk, clunk noise from front left wheel in 79 4x4 .faded.fedor. General Vehicle Related Topics (Non Year Related) 2 04-02-2007 09:14 AM
1983 pickup floorboard 91_4x4runner Pre 84 Trucks 37 10-31-2006 05:29 PM
WTB 86 pickup sr5 5spd knock sensor and drivers side window crank 86blueyota The Classifieds GraveYard 4 09-16-2006 10:48 PM
Getting a clunk on pass side under breaking. lilwily 95.5-2004 Tacomas & 96-2002 4Runners 5 11-16-2005 06:39 PM
2009 InternetBrands, Inc.
