87 4runner would like to SAS - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-19-2008, 02:13 AM   #1 (permalink)
874runner's Avatar
Send a message via AIM to 874runner
Hey guys im new here. I own a 87 4runner with 3" body and 33's my question is i want to do a SAS on it and take off the body lift. but add a 4" suspension lift is it cheaper for the lift kit if i have a SAS? also what year toyota should i get the axle out of? and is there any tutorials on how to do it? any info helps! thanks.
874runner is offline
Old 04-19-2008, 06:52 AM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Welcome to Yotatech.
You need to do a LOT of reading and research because your questions clearly demonstrate you have no clue what you are asking.
A solid axle swap typically involves lifting the vehicle in order to do the swap. Most kits are 3-5".
Typically the 79-85 solid front axle is used.
Tutorials? Search the Toyota online forums and It has been done just a few times before.
Check out our website for ideas on SAS kits, rear lifts and look at the "tech info" page for SAS installation instructions.
Go read this - all of it!
http://www.pirate4x4.com/forum/showthread.php?t=459180
waskillywabbit is offline
Old 04-20-2008, 01:21 AM   #3 (permalink)
Staff
Lysmachia's Avatar
Send a message via AIM to Lysmachia Send a message via MSN to Lysmachia Send a message via Yahoo to Lysmachia
Yes welcome. We moved your post due to the nature of your post. When you do a little more research and search YotaTech or Google, and have more specific questions, then you can post under your model/year...
__________________
Molly
aka Lysmachia
93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness
Get your 4x4 VIDEO pr0n here
Quote:
Originally Posted by leebee View Post
from this gray haired old red head to you, EGO BOOST!! you go girl!
Lysmachia is offline
Old 04-21-2008, 01:53 AM   #4 (permalink)
874runner's Avatar
ok thanks. sorry im new
Old 04-21-2008, 03:56 PM   #5 (permalink)
bigarms23's Avatar
all you need is a 4inch sas kit from marlin crawler and an 83 to 85 toyota front axle gears and rebuild the front axle
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1972 stepside jimmy d44/d70 425hp
1995 green range rover
bigarms23 is offline
Old 04-21-2008, 04:00 PM   #6 (permalink)
bigt's Avatar
yeah.. i was looking into a s.a.s too but its still a little beyond me yet... first im going locked rear then well see how far i can go with that and a winch... you need a solid axle from a 83-85 toyota truck. get a kit from a company like wab fab or trailgear or marlin and you can choose the 4 inch kits .. its around 1200... if you have a first gen runner you have leafs in the rear and can get some new leafs and coils to get the lift you need. if its a newer runner you need a kit like the s.a.s
gotta run
search is your friend and so am I
welcome to yt
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 04-21-2008, 04:01 PM   #7 (permalink)
Staff
Quote:
Not quite...and front drive shaft work and then the front SAS is done.
What about the rear? Lockers? Gears? Armor? The list goes on and on and on.
Old 04-21-2008, 04:14 PM   #8 (permalink)
ocdropzone's Avatar
welcome to an addicting hobby...I feel an SAS conversion is a good route to go, but there are some folks,TC, for instance that can wheel some very difficult places with IFS because he knows how to drive.
This all Toyota Search Engine might give you another source. It hits over 50 Toyota Technical sources...
like Wabbit said, keep reading and searching. You will find that you will be abe to answer many questions you have. Of course some new ones are gonna come up
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
Last edited by ocdropzone; 04-21-2008 at 04:15 PM. Reason: fix linky thingamachigger
ocdropzone is offline
Old 04-24-2008, 04:03 PM   #9 (permalink)
bigarms23's Avatar
I could add add a set of longtravel je reel driveshafts but you can do an sas without a front friveshaft but you won't be able to use the 4wd
__________________
Old 04-24-2008, 04:17 PM   #10 (permalink)
sambeano420's Avatar
Send a message via Skype™ to sambeano420
Hi, Iam new here too, but I will throw in an answer. 84 and 85 front axles are best, they were beefed more from the factory, but would add the weld on armor and ball braces and longfields. Also recommend going to 63" 3/4 ton Chevy springs in the rear, with the bottom 2 leaves taken out. did it to a buddys 85 and it flexes incredibly.
sambeano420 is offline
Old 04-26-2008, 10:09 PM   #11 (permalink)
874runner's Avatar
Well thanks for all the input guys. Im not sure if im built up to the SAS yet i want to do it but need to read further it looks like. Besides ive only had the truck not even a year yet lol. So far it wheels very nicely the way it is but maybe i should do gears and lock the rear first?
Old 04-26-2008, 10:15 PM   #12 (permalink)
Spence1016's Avatar
Send a message via AIM to Spence1016
Quote:
that would be the best place to start, there are very few places you can get with a sas that you cant with ifs
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[
Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells
Foglights on bottom of rear bumper
Optima Yellowtop, Kc daylighters on front bumper
Vortex muffler and Trueflow airfilter
Spence1016 is offline
Old 04-26-2008, 10:22 PM   #13 (permalink)
874runner's Avatar
well im sort of new to wheeling as well but so far every terrain and/or trail ive taken it down its never had a problem couple took a few tries but it made it every time.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
My '94 4Runner SAS Blizzard Solid Axle Swaps, All Years 126 04-06-2009 01:45 AM
88 4Runner SAS in MN rockota The Classifieds GraveYard 2 07-08-2007 03:40 PM
93 4runner SAS jla123 The Classifieds GraveYard 17 04-25-2007 01:18 PM
SAS 87 4runner superman180 84-85 Trucks & 4Runners 19 04-09-2007 04:08 PM
2009 InternetBrands, Inc.
