87 4Runner Clutch Master & Slave - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 02-20-2010, 08:49 AM   #1
I am about to replace the master and slave clutch cylinders. Can I save more time by replacing one before the other? Which one first?
BornToRun is offline   Reply With Quote
Old 02-20-2010, 10:12 AM   #2
myyota's Avatar
Replace the slave cylinder first.
myyota is offline   Reply With Quote
Old 02-20-2010, 05:48 PM   #3
That was fairly simple. The only issue I had was the new Master Cylinder's push rod was a bit long. I laid the new cylinder down beside the old one and tried to adjust the clevis position similar to the old one before I installed it. That didn't work out as well as I'd hoped. The end of the push rod was touching the back of the clutch pedal assembly.
Any way, the pain is over and she's back on the trail.
Icentropy's $400 4runner build icentropy 86-95 Trucks & 4Runners 14 10-22-2016 10:24 PM
Please help! smthwsn357 86-95 Trucks & 4Runners 7 04-11-2016 06:22 AM
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
'94 3.0 Pickup Clutch Pedal Sticking Kalihi,HI 86-95 Trucks & 4Runners 3 07-09-2015 05:29 PM
Tags
22re, 4runner, 87, 88, 91, clutch, cost, cylinder, diff, front, master, replace, replacement, runner, slave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
