5VZ-FE swap to 4 Cylinder Engine - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 04-15-2012, 11:43 PM   #1
Hello out there. I may need to replace my 5VZ-FE in my 1997 Tacoma 4x4. I was just curious whether or not I could swap out the engine for a 4 cylinder? I would not be doing the work myself, and just wanted to know if anyone here has successfully done this. Thanks for reading this.
TacoTaco97 is offline   Reply With Quote
Old 04-16-2012, 12:16 AM   #2
wyoming9's Avatar
Red face
Most go the other way I don`t know of anyone who has gone from a 3.4 to a 4 cylinder
What possible motive could you have for doing this???
If your paying to have it done it will be cheaper to fix your engine or replace with what you have in there.
Till you get done finding a 4 cylinder buying that and doing the swap.
Unless someone is doing this that does these kind of swaps it is going to be a learning experience for them and quite expensive
It can be done but for how much is the ????
wyoming9 is offline   Reply With Quote
Old 04-16-2012, 01:53 AM   #3
Thanks for the reply Wyoming9! Well, I thought I would save money by getting a smaller engine both up front and at the gas pump. But I see your point that it will cost me a lot of $$ for someone to do necessary modifications to make it work.
Old 04-16-2012, 06:22 AM   #4
Texas_Ace's Avatar
Only reason to go with a 4 banger of the V6 is if you plan to turbo it, you can turbo the 4 banger easy.
Otherwise just replace it with another V6. Gas mileage will be about the same or better with the V6 honestly depending on how you drive.
Texas_Ace is offline   Reply With Quote
Old 04-17-2012, 12:58 AM   #5
Thanks TA for the advice. Still waiting to hear back from my mechanic whether I need a new engine or not. I think I will just stick with the V6 engine if it will be less complicated and if there won't be too much benefit to convert it to a 4 cylinder engine.
Old 04-17-2012, 06:14 AM   #6
LOL it will cost you WAY more to swap a different engine in, rather than rebuilding what you have.
Greg_Canada is offline   Reply With Quote
Wiring help toyotamonster 3.4 Swaps 6 12-30-2016 05:38 PM
87 22r rebuild issue bigjstang 86-95 Trucks & 4Runners 14 12-09-2016 10:16 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller coryc85 Misc Stuff (Vehicle Related) 6 09-09-2015 07:24 AM
83 pickup lift and engine rebuild God's Bounty Hunter Pre 84 Trucks 6 07-08-2015 01:54 PM
New AC Questions (Not the same old ones) HRDC0R19 86-95 Trucks & 4Runners 3 07-05-2015 07:43 PM
Tags
34, 4runner, 5vz, 5vzfe, banger, cylinder, doug, engine, fe, good, sale, swap, thorley, toyota, vz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
