4x4 will not engage - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2009, 08:22 AM   #1 (permalink)
4x4 will not engage
Hey I'm new here and i just bought a 1990 Toyota pickup 4x4 5spd 22re
i tried the 4x4 and thought it worked because when i shift from 2h to 4h i can hear a click in the dash but the 4x4 light does not come on, so i tried 4l and it felt like it was working because the gear ratio was so low so i figure the transfer case is ok. so i tried using 4h to get out of a little jam and the front wheels were not spinning.
what are the things i should check first
please help
craigory1983 is offline
Old 10-25-2009, 08:40 AM   #2 (permalink)
Kiroshu's Avatar
Connectors on transmisson. Any hanging off or not in the right place? Wheel hubs locked?
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 10-25-2009, 08:47 AM   #3 (permalink)
Well I looked underneath and didn't see anything hanging or anything and if I'm not mistaken the front hubs are always engaged I think the diff has something engage the axles
Old 10-25-2009, 08:51 AM   #4 (permalink)
Kiroshu's Avatar
Do you manual lockers or auto? if namual you have to get out and turn them.... if auto then no.... you could jack the rear off the ground and put it in 4wd and see if it pulls the truck off the jack lol. Or jack it all up on stands and see..... if the front wheels are not turning and the light is off.... then something is disconnected.... look hard... i hard the same issue after i did a clutch in a buddys truck i forgot to reconnect one lil connector and it kept the 4wd from working......
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
Kiroshu is offline
Old 10-25-2009, 09:46 AM   #5 (permalink)
Team420's Avatar
vacuum lines, or electrical connectors to the front diff.
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 233k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 235k on the clock.
It's becoming an addiction.
Team420 is offline
Old 10-25-2009, 07:20 PM   #6 (permalink)
eric-the-red's Avatar
If it's got ADD read this.
http://www.off-road.com/trucks4x4/ar....jsp?id=399612
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 10-26-2009, 02:49 AM   #7 (permalink)
Yorkie's Avatar
I had exactly the same problem. It was a vacuum line the got connected incorrectly the last time it was in the shop. Follow the vacuum line up from the ADD up to the passenger side of the engine bay. It goes into a small black box and comes out the other end. With the engine running, pull the line and see if there is any vacuum there.
Yorkie is offline
Old 10-26-2009, 03:23 AM   #8 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
please help
The click in the dash means the switch at the t-case works, but the light not coming on means the actuator is not moving over to engage the diff w/ the axle. So, somehow you are not getting vacuum or the actuator itself is not working right.
Look at the front diff for the two vacuum lines going to the actuator to right (as your facing it) of the diff. If they aren't disconnected there and/or have no holes in them, trace them back all the way to the two vacuum switches they go to. Not sure where they are on your truck. They're under the hood on top of the pass. side wheelwell in a 2nd gen 4rnr. Anyway, make sure they are connected there and that the switches function = creating vacuum. If all appears well, the hoses may just be switched around.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 10-26-2009, 03:15 PM   #9 (permalink)
thanks for all the help guys. It seems the steel connector for the vacuum line rotted away so now i just have to figure out if i can fix it or if i have to replace the add
Old 10-27-2009, 05:28 AM   #10 (permalink)
thook's Avatar
How badly? Can you get a pic?
__________________
Matthew
thook is offline
Old 10-27-2009, 07:10 AM   #11 (permalink)
JShaffer0525's Avatar
Send a message via AIM to JShaffer0525 Send a message via MSN to JShaffer0525
not really sure exactly how add works but would just switching to manual hubs fix this and negate the need for the vacuum lines? probably a noob question but im just trying to learn!
__________________
1987 4runner 22RE
cupholders!
05 Tundra 16in aluminum rims
BFG ATs
Quote:
Originally Posted by 75k5toy View Post
...If drinking while working on our trucks causes mistakes, so what, that's a good excuse to work on the truck and drink again, next week. :cheers:
troubleshooting problems is serious. ;)
otherwise we could throw playdoh at it all day. :D
JShaffer0525 is offline
Old 10-27-2009, 07:12 AM   #12 (permalink)
Team420's Avatar
no... with the add flanges, your hubs are always locked... the problem u are having is that your front diff is not engaging. Gotta fix thos vacuum lines, or manually lock the diff. then add the manual hubs.
__________________
DD:
Project:
Team420 is offline
Old 10-28-2009, 07:06 PM   #13 (permalink)
i managed to drill out the broken connector and pressed in a piece of 3/16 brake line as a new connector and reconnected the vacuum line now the 4x4 works great. thanks for all the replies and suggestions i really appreciate it
Old 10-28-2009, 07:26 PM   #14 (permalink)
SigEp4Runner's Avatar
This same dang thing happened to me after my buddy rebuilt my transmission!! Thanks to this thread I can show him where he f-ed up or just do it myself. Since I paid to have the thing fixed to begin with, and I got stuck once, I might as well have him do it.
__________________
Link to member profile http://www.yotatech.com/showthread.php?t=117298
SigEp4Runner is offline
Old 10-29-2009, 10:07 PM   #15 (permalink)
thook's Avatar
I was going to suggest something like that. S'why I asked how bad it was broken. Congrats to a DIY'r...
__________________
Matthew
thook is offline
Old 11-03-2009, 11:04 AM   #16 (permalink)
323gtx's Avatar
hey guys im having a similar problem with my front diff not engaging im getting the light on the dash coming on so im assuming that the actuator is engaging the switch and i have check and do get vacume from the right hoses at the add what else could be wrong if the actuator is engaging the light transfer case is good front drive shaft engages when in 4wd
does there need to be a certian amount of vacume to engage the diff over and less vacume to engage the switch?
help would be nice
cheers
frank
323gtx is offline
Tags
1990, 22re, 2nd, 4runner, 4x4, 5spd, case, engage, gear, generation, pickup, ratio, sr5, toyota, transfer, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
