4X4 manual hubs & ADD sys. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-29-2008, 11:28 AM   #1 (permalink)
22RE_yota's Avatar
I am having an issue with my hubs if in 4x4 high & low and my hubs locked, I have this random grinding/clunking noise which lasts a few seconds then dissapears. if I leave the hubs locked and drive around in 2wd, it does the same random noise. I have pulled apart the drivers side, and noticed some slop between the spindle shaft (part of the CV) and the spindle carrier, it turns out Toyota calls them steering knuckle bushings. I plan to replace them (both in and outer) but I would like to know whether this could be the most likely culprit, or if anyone knows the specification on the wear tolerences for these bushings?
any help is appeciated thanks.
__________________
FOR SALE:1991 Toyoya pickup 4X4, Grenade Green/grey. Reg. cab & long box, 22RE & 5spd. Original 181345kms!
Other stuff:
-LC Engineering Header
-Downey Off road cold air intake
-KYB MonoMax Shocks
-31x10.5x15 BFG All Terrains
-AISIN manual hubs
-Factory Box Liner
NEW TRUCK!
2003 Taco 4x4, silver/grey. Extened cab. 2.7L, 5spd.
Bone Stock! With 31523Miles
22RE_yota is offline
Old 01-29-2008, 11:30 AM   #2 (permalink)
tc
tc's Avatar
You got the right part, but the wrong diagnosis.
You just need to grease the bushings. you can either pull the CV or there's a writeup on how to make a device to lube them up without having to.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 01-29-2008, 08:30 PM   #3 (permalink)
22RE_yota's Avatar
ok, well the parts are on order...I caved, from what I had taken apart yesterday...it seemed as though the driver's side has more play in it vs the passenger's side, so thanks anyways, I am planning on building a grease packer myself, but the write up was helpful, thanks alot
__________________
Other stuff:
-KYB MonoMax Shocks
-AISIN manual hubs
-Factory Box Liner
NEW TRUCK!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
ADD to Manual Hubs johnperrone11 86-95 Trucks & 4Runners 49 02-05-2006 07:40 AM
Are ADD hubs pretty much just manual hubs that are always locked? GradSR5 95.5-2004 Tacomas & 96-2002 4Runners 29 11-14-2005 12:02 PM
ADD Hubs to manual hubs corvettelvr73 95.5-2004 Tacomas & 96-2002 4Runners 4 01-13-2005 10:25 AM
Can I have manual hubs on a 4R with ADD? Los Gatos? 95.5-2004 Tacomas & 96-2002 4Runners 8 01-14-2004 02:49 PM
add to manual hubs airrikk17 95.5-2004 Tacomas & 96-2002 4Runners 4 05-04-2003 08:36 AM
2009 InternetBrands, Inc.
