3vze engine falters - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2009, 06:57 AM   #1 (permalink)
acorvet's Avatar
3vze engine falters
I have a 92 4-runner 3vze 5 sp 4wd with 250k on the ticker. When I depress the gas, the engine will begin to speed up (from 1000 rpm to 2500 rpm) and then it stops running. No engine codes. the engine will begin to fire again for a second or so and falter again. This is a repeatable process. I can not get the engine to run above 3,500 rpm. All of this is with no load. I recently installed a new fuel filter. no change. New TPS, no change. unplugged the mass air flow and the engine dies. I pulled the fuel tank and it seems clean and the fuel pump filter screen appears to be clean. How can I test the fuel pump? Any idea on what could be wrong would be most appreciated?
acorvet is offline
Old 10-25-2009, 07:14 AM   #2 (permalink)
Kiroshu's Avatar
If had to make a guess i'd say EGR. Unplug the vac line(s) to it try and see what happens.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 10-26-2009, 08:44 PM   #3 (permalink)
acorvet's Avatar
The EGR valve seems ine and is not making that deep thraoty sound when I punch the accelerator. Any other ideas?
acorvet is offline
Old 11-01-2009, 03:34 PM   #4 (permalink)
acorvet's Avatar
So, I have validated fuel is not the issue. I am able to get the truck to idle and the fuel pressure stays around 40. I have put my timing light on the coil to dist wire and the pulsating light seems consistient. As soon as I depress the accelerator the the engine falters (generally it stalls) and there is no spark according to what I see with the timing light. I just replaced the coil and ignitor and it did not improve. I appreciate your experiance and response!
acorvet is offline
Old 11-01-2009, 03:54 PM   #5 (permalink)
acorvet's Avatar
and, the oil pressure is in the normal range.
acorvet is offline
Old 11-02-2009, 10:47 AM   #6 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Check the air intake boot. Those things like to rip, and cause unmetered air into the intake
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 11-02-2009, 12:00 PM   #7 (permalink)
Team420's Avatar
had the same thing happen to me on a s-10... turned out the cat was plugged.
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Old 11-03-2009, 06:58 AM   #8 (permalink)
acorvet's Avatar
case resolved - Rotor and cap... lot of work went into a simple fix.. bummer - Thanks everyone
acorvet is offline
Tags
3vze, engine, fuel, pressure, pump, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
