3rd Gen 4runner grinding when turning
Old 07-20-2012, 06:12 PM
amcor's Avatar
I hope this isn't a dumb question, but I've done a lot of searching and haven't been able to find my exact problem, or at least not a satisfactory answer to it.
When I turn the steering wheel about one revolution to the left, I hear a grinding noise that sounds like metal on metal. It sounds like it's coming from the front driver side wheel well area. If I turn it further, it stops. The grinding noise will show up even more and not exclusively in that one spot on the wheel if I turn with the left tire over a bump.
Basically, I'm wondering what is going on, if it's safe to drive, and how I can fix it. From other threads I have read, I am hoping that lubrication will fix it, but I'm not entirely sure what to lubricate.
Thanks in advance.
Old 07-20-2012, 07:28 PM
StewsRunner's Avatar
is it grinding or more of a tension thing? if it's more of a tension thing i would check your power steering level. .
Old 07-20-2012, 07:45 PM
BigBluePile's Avatar
Steering stops?
Old 07-23-2012, 01:49 PM
amcor's Avatar
I've checked the power steering and it seems to be fine. It definitely sounds like metal on metal, but only when steering left. Once in a while it sounds worse and kind of pops.
I don't think it is the steering stops because it happens when I don't have the wheel fully to the left.
Old 07-23-2012, 02:15 PM
cubuff4runner's Avatar
I would check your bearings.
Old 07-23-2012, 04:46 PM
djfell80's Avatar
Definitely sounds like bearings to me! Fix it soon so it doesnt damage more than just a bearing.
Old 07-23-2012, 05:14 PM
amcor's Avatar
So do I check the bearings by putting it on a jack and seeing if the wheel has any play or makes noise when I spin it? I think there is a very faint scraping when I am driving, but it's so faint that I can't decide if I'm hearing things or not.
Old 06-26-2017, 06:31 PM
Stuman's Avatar
Grinding
What did your problem end up being?
I know this is an old thread, but thought I would try, I am having exactly the same issue.
Steering pump was recently drained and refilled, but it shows normal level now.
Thanks
Old 07-26-2017, 05:06 PM
75w90mantraN's Avatar
http://www.dummies.com/home-garden/c...heel-bearings/
I'd spin the suspected wheel at whatever point in the steering to check. Not a big fan of the grab-and-shake-the-wheel. Grinding could be the bearings, or any misaligned component in the steering knuckle/suspension assembly in contact with the hub/rotor/wheel.
Could also be brake pads/rotors if the pistons aren't retracting or even bent brake dust shields over the caliper/wheel, though with these, it be more noticeable with any forward/backward movement.
If its the power steering, there'd be a screeching noise with turning of the wheels while the engine is running. I used to have that noise mod.
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 3rd Gen 4runner grinding when turning
