3.0 swap
Old 01-13-2010, 04:33 PM
Dumpster Dumper's Avatar
3.0 swap
I have a 1992 truck 4X4 w/ 3.0 . Its shot, and I m going to swap it for a 3.4 . What i've read is that its a matching replacement, and a better replacement then the 3.0 . Its mated to a 5 sp. trans. My questions are, how much more power does it have ? Will it work w/ my same computer ? Will any of the toyota 3.4s work or do I need a 1992 ? Lastly , what problems will I encounter on the swap...
Thanks
Old 01-13-2010, 05:17 PM
brian2sun's Avatar
Here's what I can tell you:
The 3.0 has 145 hp, the 3.4 has 190. Big difference and you can feel it. I had a 3.0 4runner and it was a dog compared to my 3.4 4runner.
I don't think it will work with your same computer because the 3.0 had the ODB1 diagnostic system and the 3.4 uses the OBD2. I have never done a swap so I'm not an expert by any means, but I'm sure that info is in the engine swap section.
You can't get a '92 3.4 because they weren't offered until the 95.5 Tacoma.
Old 01-13-2010, 08:55 PM
edwinb4x4's Avatar
Here u go - all the info you will need and then some. - (4x4wire has the most info imho)
http://www.4x4wire.com/index.php?opt...sion&Itemid=53
https://www.yotatech.com/forums/f160...started-82145/
https://www.yotatech.com/forums/f160...4-swap-101174/
http://www.pirate4x4.com/forum/showt...5&pagenumber=1
Old 01-13-2010, 08:58 PM
paynemw's Avatar
look for a 3.4 with supercharger!!! but i think you might need to get a hood buldge or get a hood scoop. I know that there's some SAS thread on here where the guy swapped a 3.0 for a 3.4 in his 2nd gen runner and he had clearance issues, but i also think its because of all the mods he had on the truck... good luck dude
Old 01-13-2010, 09:09 PM
rhill's Avatar
you have a lot of research to do...i think there's a whole forum section of threads dedicated to this i'm if not mistaken....
yep. here it is. read up.
https://www.yotatech.com/forums/f160/
Old 01-14-2010, 05:46 PM
Thanks for the info . Much appreciated.
tobylab
01-18-2016 07:06 PM
Alex Bessinger
08-31-2015 09:17 AM
93toyoguy
08-02-2015 07:41 PM
tobylab
07-12-2015 12:53 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3.0 swap
