2nd gen 3.4 swap
2nd gen 3.4 swap
Hello to all. I have been researching this site (along with others) for months now but this is my 1st post. Forgive me if there is a post on this site somewhere that has the answer to my questions and I might have missed it. If there is can someone please point me in the right direction. If not then this is my question. I have a 1992 4Runner. I bought it from a guy with a rod through the oil pan. He was the 2nd owner and he had it for 7 years. It is in beautiful shape and I got an incredible deal on it. I was just going to put another 3.0 in it but after some research, I decided it would be better to upgrade. A friend wanted me to put a Chevy 350 in it. After researching that idea I decided not to. I don't want to put that much of a lift on it to clear everything and I don't have the funds. I have been researching the 3.4 swap. Instead of a body lift, I am going to cut the hood and put a minor scoop on it. I am putting a 3" suspension lift on it with 33" BFG AT's at the most. I don't really like body lifts and I have a quad I need to tow so I don't want to go to extreme on the lift (plus I need the truck to fit in my garage). The question I have is if this motor will bolt up to an auto tranny. I know it will bolt up to a 5spd but the guy I bought it from had the tranny rebuilt 13k miles ago and I have all the paperwork for that. This is my 4th Toyota truck but my 1st auto tranny. I really don't want to convert it to a manual. I know there is exhaust work that needs to be done which is no problem. I am going to run factory manifolds and I know I need to get a crossover pipe. So other than the engine, wire harness, ecu, crossover pipe, exhaust work, and hood fabrication, is there anything else I need to know? I am sorry for the length but I want to make sure I covered evrything. Thank you in advance for your help.
http://www.offroadsolutions.com/technicalarticles.htm
You can fit 33x10.50 with no lift on the factory rims.
Thank you for the link. That answers pretty much every question I had.
I am going to run 33/12.50 tires. I already bought 15x8 wheels with a 4.5" backspacing so I will need to lift it a little to clear the width. Thanks for the info.
Flying91
45
04-11-2024 04:39 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
Steezy96yota
07-06-2015 10:00 AM
