22re running rich! Any advice on what to do? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-06-2008, 10:32 PM   #1 (permalink)
94toy4x4fever's Avatar
I have a new 22re with like 700 mile on it. I have been having some pinping problems and it seems to be running rich. Any advie on what I should so? Timing is set at 5*. Please help! Thanks
94toy4x4fever is offline
Old 03-06-2008, 10:52 PM   #2 (permalink)
4Crawler's Avatar
Assuming "pinping" is pinging (knocking), then that is usually from running too lean or from timing advanced too far. Since you say you have timing at 5 (BTDC - with the timing jumper installed I am assuming), then you might want to test your O2 sensor.Also, see if there are any store trouble codes, could also be the knock sensor.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 03-07-2008, 08:57 AM   #3 (permalink)
tc
tc's Avatar
It seems to take a lot for the O2 sensor to throw the CEL.
x2 for testing the O2 sensor
FSM for a '93 truck (yours should be identical) here:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 03-07-2008, 09:59 AM   #4 (permalink)
sloppy85toy's Avatar
im havingh the same trouble.its smoking a little and the valves r knockinking with only 3000 miles.what is a timing jumper.
__________________
(sloppy85toy) 85 sr5 4runner 22re 5.29 spooled rear sittin on three inch lift and 33 inch boggers
sloppy85toy is offline
Old 03-07-2008, 10:00 AM   #5 (permalink)
i was wondering why the timing wasnt staying true.
__________________
Old 03-07-2008, 10:01 AM   #6 (permalink)
4Crawler's Avatar
Quote:
Timing jumper:
http://www.4crawler.com/4x4/CheapTri...CheckConnector
And check the TPS:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 03-07-2008, 10:55 PM   #7 (permalink)
thanks
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota Running Rich/Running Lean? NEED HELP! mrboyertown Newbie Tech Section 3 05-18-2007 01:19 AM
22RE running rich yotamanmn 86-95 Trucks & 4Runners 9 05-12-2007 05:19 PM
22RE running rich cweich 86-95 Trucks & 4Runners 9 10-03-2006 11:15 PM
22re running rich stevrock 95.5-2004 Tacomas & 96-2002 4Runners 3 12-30-2004 12:29 PM
22re running rich bain 95.5-2004 Tacomas & 96-2002 4Runners 1 11-02-2004 04:16 PM
2009 InternetBrands, Inc.
