| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE head gasket HELP :(
#2 (permalink) |
I would threaten to take that hack to court. I would have an attorney write him a letter if he doesn't own up to the damage he caused. If he's a real shop, you will probably win. If he's an under the table kind of guy, you might still win - doubtful, but still worth a try.
It sounds like all the problems you are having now were caused by him and his ignorance.
__________________
97 4Runner SR5 3.4L 4x4 305/70R16 Mastercraft M/Ts on black stock 6 spokes 2.5" suspension lift ARB Bullbar ARB rear locker 4.88s Factory wood grain dash My 4th Toyota truck "If guns kill people, then pens write novels." |
#3 (permalink) |
OK. Where to start.
Brian is right that your problems are probably due to the previous guy reinstalling your broken TC cover. The big if there is whether its worth the trouble to go after him. Lets clarify, the cylinder closest to the TC cover is #1 and they run 1234 front to rear. If your TC cover is chewed up inside and allowing the oil and coolant to mix you probably wouldn't see it leaking on the exterior of the engine. Certainly not at the #1 cylinder. More likely, the defect in your TC cover where that guy made the half baked repair is preventing you from getting an adequate seal/clamping effect at the front of the cylinder head/block/TC cover junction and allowing leakage. You also have some responsibility for not installing the right gasket last time thereby increasing the pressure in your cylinders and putting more stress on all aspects of the head. Sadly that might be all the other guy needs to get out of his part in this. Also, when you noticed the leaking this time around did you continue to run the engine or stop right there? Assuming you haven't overheated again, I imagine your head is fine. If you can have the truck down for a while here is what I would do... Order a new TC cover (it's established that your current one is toast) and headgasket kit. Pull the head and TC cover. Inspect the stuff under the TC cover (i.e. oil pump, timing chain and tensioner, guides) If you have any questions about the parts you inspect, get new ones and install. If it all looks good, reassemble with the new TC cover. Get the right thickness of headgasket or a shim. I don't know much about the shims as most rebuilds on here haven't required them, but if you machine off enough of the head you have to return the whole assembly to stock specs (as your machine shop guy recommended) Hopefully you still have the info on how thick a shim/spacer you need. Check the rebuild thread by olharleyman. He had to put one in and probably can give you some advice. OK. I'm getting to where I can't remember what I have and haven't already written. Chew on that for a while and come back with any Qs. Good luck.
__________________
86 4Runner, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, rear Lockright, SAS w/ARB My build thread. http://www.yotatech.com/f66/blknblu-s-sac-155872/ |
#4 (permalink) |
Thanks so much for your help guys!
I did not continue to run the truck more than lets say... 2 minutes not under load at idle in my garage. I could order a new timing cover, and new gasket kit and redo the whole job. which isnt a big deal since I have a daily driver. it just sort of leaves me wondering why its coming out of both ends (intake and exhaust) on cylinder 1. and why now if it has always been cracked and ran for a good while. Maybe original cause of HG failure and finally its the TC is toast. I am beginning to think maybe from the girlfriend overheating damage there is chance the block warped. As far as the mechanic is concerned, I have no way of contacting him, he moved locations about an hour away from where I live in Irvine, to the inland empire. Lucky for him I guess. Second option is to have the long block replaced, if it is shot, I found a reputable place that will charge me 600 for core and around 600 for the install, assuming that my core is good, otherwise the total price will increase. I drop it off with my AAA and come back a week later, and have a running truck witha year warranty. Or I can sit on it for a while let the truck take up the space in garage, which my roommate isnt too happy about lol (technically my side of the 2 car garage) and do the motor install over a couple weekends myself and save some cash.. but honestly after all the money ive already spent, it may be wiser and less of a headache to dish out a couple hundred extra and have some peace of mind. or save money and start 1jz project.... LOL only kidding. Anyway thanks for the help, Ill think about it and see what happens. I can always try to haggle my parents into sending me some money, maybe split the cost in half.... if im lucky. probably wont happen though
#5 (permalink) |
I doubt your junk is warped. If you didn't overheat the head after the rebuild it should be fine. Usually the head is the first to go. The block is cast iron and huge in comparison to the head so, while possible, warpage is unlikely without extreme abuse. You would have the head off anyway so it would be easy enough to have that rechecked, and you can run a straight edge over the block. (not perfect but better than nothing) I'm still betting on the poor clamping effect of that broken TC cover. Look at this:
![]() Borrowed this from 92 Toy's thread. You have good bolts at the red arrows but a poor clamping effect at the green arrow. I can't say for sure but that may effect the integrity of the whole shebang enough to cause failure. The yellow squiggly line is where my head gasket failed (though on the other/exhaust side... it was just easier to draw it on the intake side for this illustration) even though my bolts were all intact. I just think it's quite possible that having that area inadequately secured could have allowed leakage on both sides of the head. Also just thought of this... did you put sealant at the 2 spots up front where the HG covers the head/block/TC cover junction last time you reassembled?
__________________
#6 (permalink) |
Hey thanks for the mention, I thought that picture looked familiar.
Jumping in, in the middle here, but that "hidden bolt" in the middle is also what I've read is the culprit when replacing the timing cover without removing the head. I've read plenty that have done it without problems but those that had problems was due to disrupting the seal of the gasket and/or not getting a proper seal at the front of the gasket over the timing cover.
__________________
1992 4x4 shortbed /22re/auto/192,000 miles--original owner(rebuild in process) 1988 SR5 4runner /V6/5 speed/248,000 miles/bought April 2009/***UNDER CONSTRUCTION*** 2006 SR5 4runner (the wife's)....still being paid for... >>>>***Check out My SLOOOOOOW Re-build Thread***<<<< http://www.yotatech.com/f116/92-toy-...-start-188472/ |
#7 (permalink) |
PS.....that's not coolant you see there on my block, it's watery oil......was not running coolant at all, just water and THERMAGASKET.
__________________
#8 (permalink) |
im going to take it all apart, again.... however I spoke with my father and was able to talk him into lending me the $600 for a new longblock, just in case mine is toast.
Once again, I really appreciate all the the help. |
| Tags |
| 22, 22re, coolant, cost, cover, cylinder, gasket, head, irvine, leak, machine, oem, seconds, shop, smoking, started, thicker |
