22re fan clutch
Old 11-01-2008, 09:36 AM
94toy4x4fever's Avatar
22re fan clutch
I need to put a new fan clutch on my 87 4runner today! Need a little help on how to do it! Also does any one have the online service manual for a 87 toyota 4runner? Thanks for the help!
Old 11-01-2008, 09:50 AM
jason191918's Avatar
Download the one on here:
http://www.ncttora.com/fsm/index.html
Old 11-01-2008, 10:09 AM
4Crawler's Avatar
4 bolts hold it to the water pump shaft and pulley. Loosen the water pump/alt. belt and remove the old clutch, install the new one, tighten the 4 bolts and the belt and you are good to go.
Old 11-01-2008, 04:40 PM
ok got the fan clutch done! I dident have to take the belts loose. Just pulled the 4 nuts holding the fan clutch to the water pump pully! I do think it would of been alot smoother going if I did pull the belts loose! But is done now and doesnet make any noise now! Thanks guy for the help!
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
coryc85
09-09-2015 06:24 AM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
Quick Reply: 22re fan clutch
