1992 4RUNNER/Surf front suspension - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-10-2009, 04:15 AM   #1 (permalink)
Is it possilbe to take out the current front suspension that has torsion bars and replace it with later model 4Runner's coil spring set up ? I believe the coil spring set up was introduced in 2003/4?
If yes, then can someone please post detailed pictures of the swap. I do not want to put leaf springs on the front.
Regards
Sajid
sajidd is offline
Old 03-10-2009, 07:30 AM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Anything can be done with enough fab and welding work.
Now is it a bolt in affair? Not even close. The two suspension setups are completely different.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by BigBluePile View Post
Wow. That thread was all: WHOA! and then wth?! and then ahhhhh!! oxoxo's! and then TAKE THAT!!
Quote:
Originally Posted by vital22re View Post
Well josh, he also gets an all expense paid trip to my fist! There he'll enjoy multiple face dislocations and steeltoe kicks to shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiin ...
DeathCougar is offline
Old 03-10-2009, 07:33 AM   #3 (permalink)
tc
tc's Avatar
x2 for Deathcougar's post.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 03-10-2009, 09:59 AM   #4 (permalink)
Guys, down here in Karachi, Pakistan we have plenty of fabricators.. so thats not a problem. All I need are pictures and diagrams..
sajidd is offline
Old 03-10-2009, 10:13 AM   #5 (permalink)
Staff
Don't have solid front axles in 1992?
We switched to IFS in 1986, and they redesigned the system in 1996 to a coilover system. I was confused when you were asking about leafs at first, but if you have a SFA, it makes more sense.
If you have Torsion bar IFS, there isn't really anything to be gained by switching to a coilover system, other than a slightly smoother ride.
You asked if it was possible to do it. Sure, anything in the world is possible. But is it really plausible? No, not really.
__________________
Old 03-10-2009, 11:28 AM   #6 (permalink)
I have torsion bar in the front. Problem is that the front bounces a lot, although i have ARB shocks and and Torsion bar.
I need the front end to be stiff, in fact very stiff as my application is rally racing. I am considering a dual shock set up.
The other option in addition to going with dual shock was to convert the front in to coil spring, but you say that not much will be gained by that.
So what are my other options?
sajidd is offline
Old 03-10-2009, 12:26 PM   #7 (permalink)
bigt's Avatar
long travel kit to keep it ifs or a solid axle from older toyota truck.
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
\m/ WARNING DIESEL FUMES MAKE ME HORNY \m/
bigt is offline
Old 03-10-2009, 12:49 PM   #8 (permalink)
flashkl's Avatar
The level 2 total chaos long travel kit converts the front end over to a coilover setup while also gaining you a ton of suspension travel. It's pricey though, and gonna cost an arm and a leg to get to Paki.
__________________
Quote:
Originally Posted by cackalak han View Post
Instead of using various nuts as size references, can you post the actual measurement?
Quote:
Originally Posted by toylocost View Post
Maybe he just likes nuts?
KaiYota - '92 Pickup Xtracab 4x4
3vze - Magnaflow Cat - Flowmaster 40 - 4 inch lift - 35x12.5 KM2s - Rear Lockright - Hella e-codes - NHOR custom front bumper
http://picasaweb.google.com/flashkl/KaiYota
flashkl is offline
Old 03-10-2009, 12:50 PM   #9 (permalink)
flashkl's Avatar
http://www.chaosfab.com/95200.html
__________________
flashkl is offline
Old 03-10-2009, 02:45 PM   #10 (permalink)
tc
tc's Avatar
Alot of the desert racing guys over here PREFER the torsion bar setup. You can get stiffer torsion bars from Downey and probably ARB/OME.
The other option would be to dial some "crank" into the torsion bars which raise the preload, meaning it takes more force to actuate the suspension.
__________________
tc is offline
Old 03-11-2009, 12:39 AM   #11 (permalink)
Thanks guys.. Total Chaos looks great but its too expensive. Frieght will also kill me.
How abut simply making it dual shocks? would that do the trick i wonder?
sajidd is offline
Old 03-11-2009, 02:51 AM   #12 (permalink)
flashkl's Avatar
I don't see the need...these trucks are light enough that you shouldn't need the dampening of two shocks per wheel, unless your current shock is on its way out or is a cheapie.
__________________
flashkl is offline
Old 03-11-2009, 03:03 AM   #13 (permalink)
Current shocks are ARB EMU.
Also am wondering how would she handle if I put coil over shocks from 1996 4Runner in a 1992 4Runner?
sajidd is offline
Tags
1996, 4runner, front, karachi, problems, sale, surf, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Should be a simple question, 1992 Toy Pickup receiver same as 1992 4runner? Maximus924 86-95 Trucks & 4Runners 7 11-21-2008 10:22 PM
03 4runner squeaky front suspension sshick 03+ 4Runner/GX470, & 05+ Tacomas 2 10-03-2008 09:46 PM
Ome front suspension 96-02 4runner dboat The Classifieds GraveYard 6 04-24-2008 05:09 AM
Diecast Tomica 1992 Hilux Surf currently for sale on Ebay Rock Slide Off Topic Talk 0 01-04-2007 12:20 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
