| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1986 4Runner fluctuates temp???
#2 (permalink) |
I would start with the thermostat first it is easy to get to.
__________________
1990 4runner, 22re, R151, 4.7, 5.29s, E-locker front, Lock-Rite rear, 37" MTRs, 51" rears all around Trail Reviews http://www.gentryoffroad.com Toyota Factory Service Manuals http://ncttora.com/fsm/index.html |
#3 (permalink) |
If the thermostat doesn`t fix the problem, try replacing the temp gauge sending unit, when they go bad it can cause the temp gauge to read wrong or bounce around.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#4 (permalink) |
An other thing that can cause it but I have yet to see in a toyota is having the propeller on the water pump so rotted or corroded that it is not moving the water properly. The symtoms are normally it will get hotter at an idle/low rpms and cools down at high rmps.
If your shroud is missing it will heat up at a stop/low speeds and cool at high speeds. I have also read that there is a clutch on the fan that could cause this if it was starting to go.
__________________
#5 (permalink) |
i have sort of the same problem on my 91 4runner 3.0 when im cruising shes fine but if im stopped in traffic the gauge goes up to hot but when i get going it usually cools down. another question when i shut it off and it has cooled down i look in my rad and there is no coolant in there and im not sure where its going as i can see no visable leaks or anything and my head gasket was done at 300000 kms and im at 350000kms so i dont think its burning it or anything. I also have duct tape on my air intake tube and my friend was looking and someone said that my truck could be running too lean and burning hot?? not sure what to do .. PLEASE HELP!!
sorry for the long post :s |
#6 (permalink) | |
Quote:
__________________
#7 (permalink) |
Thanks guys, it is not an issue of speed or idle. It does this as I am traveling at a constant rate of speed. I am guessing it is the thermostat, I will swap it soon and see.
#8 (permalink) |
make sure to get an oem t-stat! you will be glad you did!
__________________
90 3vze 4x4 runner mostly stock. custom isr mod, cherry bomb turbo muffler 31x10.5 Coursers with stock 4.10s hehe. custom 4runner a$$ sag :( and 1 extremely dirty lebra. (no hood scoops) |
| Tags |
| 4runner, 86, sender, temperature, water |
