1977 Hilux Project
Old 07-26-2015, 09:37 PM
PNWrider's Avatar
1977 Hilux Project
Hey all, I'm here to showcase my current project and learn what I can from you guys. As it is too late to take photos, I'll post tomorrow. I've (re)fabricated/reupholstered a bench seat from one taken out of a 2002 Chevy van, stripped the interior, and gotten all my electronics working (who decided that the flasher belonged behind the radio?!).
Living in Leavenworth, WA, I mountain bike, snowboard, and all the other outdoorsy stuff this place has to offer- which is making me want to convert this thing to 4x4. I've been reading up on the Wolverine, and it's use of a jeep dana 20 (or 30?) transfer case and axle. anyone know of any alternatives to this, from what i know, they are a little flimsy for my liking... i'll be getting better suspension/adding leafs to the back until i figure out a 4x4 conversion. Right now the truck is dead stock except for the seat and the Weber carb. (I've also pulled out that accursed smog system.)
Thanks!
Old 07-27-2015, 03:58 PM
85TurboRunner's Avatar
Just go with Toyota axles and tcase.
Old 09-29-2015, 10:12 AM
PNWrider's Avatar
UPDATE:
while helping my parents move, I blew the engine on the poor thing carrying a relatively heavy load. engine dieseled and the pistons appear to have melted to the engine... now searching for a new engine.
Old 09-29-2015, 10:48 AM
highonpottery's Avatar
I'm just going to leave this right here http://www.lceperformance.com/Race-E...ocks-s/142.htm
Old 09-29-2015, 03:40 PM
donomite49's Avatar
Yota 3rz or vw tdi with yota 4x4 axles and running gear.
Old 10-30-2015, 08:14 AM
PNWrider's Avatar
Well, crap. I mosquito coasted the thing and did the "easy" rebuild, replaced all my gaskets, etc... found that I had not seized the engine, but a bolt had ground itself between my flywheel and the bellhousing.
Engine started knocking about halfway up the chumstick highway, thought I might be too thin of oil, so I put 20/50 instead of 10/30.
made it home last night with a slight knock, only to start it this morning and have it sound as though it wanted to throw a rod. added lucas oil thickener and the problem has only exacerbated itself, all signs are pointing to a badly spun bearing. Will be pulling it apart again tonight it looks like.
(On a side note, if anyone has a 20r or a 22r that they'd donate to my cause, id be forever in your debt... i can drive to pick it up and/or work for it if needed.)
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 05:51 PM
tylermx71
09-29-2015 08:49 PM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: 1977 Hilux Project
