Items Wanted Vehicle and non vehicle related
WTB[NorAtl]: Intake Manifold Sensor
Old 08-08-2015, 05:55 AM
AudiKev's Avatar
22RE Intake Manifold Sensor
Hi,
Did the EGR delete on my truck and somehow misplaced the sensor. I need it to solder in a 10k resistor which will turn off my Check Engine Light. I want to be able to plug right into the connector on the engine harness. Sensor in question is the white one in the picture. I don't even need the actual sensor if someone wants to cut the wires off a parts truck. Just need the connector.
Old 08-11-2015, 04:57 PM
AudiKev's Avatar
This is for a 22RE
TTT
Old 08-15-2015, 03:43 AM
AudiKev's Avatar
Weekend bump!
Come on... someones gotta have a parts truck sitting around
Old 05-08-2016, 04:46 AM
AudiKev's Avatar
Originally Posted by AudiKev
Weekend bump!
Still need this...
Old 07-07-2016, 04:56 PM
AudiKev's Avatar
Bumping
Old 08-03-2016, 06:00 AM
nbl300's Avatar
Why don't you get a couple of those quick wire couplers cut it off before the connector solder your resistor inbetween 2 couplers and plug it in and if you ever want to go back just plug the connector back in and pull the sheath over the couplers
Old 09-03-2019, 02:55 PM
Howie Feltersnatch's Avatar
The connector in question is
that is for air conditioning and also for the power steering it isnt a connector that has to be connected . I dont remember where I read this info I am posting but i do know that it is confirmed good luck hope this helps you 👍
Dakotaneu
08-15-2015 07:24 AM
ksmudrunner99
08-07-2015 06:46 PM
Flossy
08-05-2015 05:14 PM
Quick Reply: WTB[NorAtl]: Intake Manifold Sensor
