WTB[MidAtl]: 22re TPS harness connector
1 Post
Looking for a 22re tps connector. The connector on my harness is cracked, so looking to replace. Will see the connector and at least a couple inches of wiring so i can splice it into my harness.
Does your connector match the one below? Their price for their kit/wiring is extremely expensive, but I make harnesses and such for ATV's, and if that connector is correct I could most likely sell a pig tail replacement with oem color matched wiring for a fair price. Based on my research and the site below, that connector was only used on 89-95 22RE engines, the older style I can't seem to source the connector on for new.
http://www.lceperformance.com/22RE-R...-p/1063034.htm
I see, so you do need the older gen connector. I might be able to hack one off an 86 re, but I'm not sure how soon I can do that, I'd like to get the engine sold before hand to be sure the buyer doesn't need any of the connectors off the orig harness (it's already hacked up pretty bad).
1 Post
That would be awesome if you would be willing to cut the harness up. Would love to have it within the next 2 weeks, but i understand you not wanting to cut it up until the engine is sold. The truck is currently my daily driver, so would love to fix this asap.
90% sure I have one with a bit of wire on it. You could also unclip your wires from the plug and just clip them back into the new plug to avoid cutting/splicing. Let me check when I get home.
It has about 2 or 3 inches of wire. It's missing the little metal clip that secures it to the TPS. Rubber boot is still pliable and not torn. What's it worth to you?
https://i.imgur.com/OjiFidl.jpg
https://i.imgur.com/Gxt1HOB.jpg
