What it takes to Convert a Prerunner 4.0 Ext cab TRD to a 4 wheel drive. - YotaTech Forums
Go Back   >
Click Here
LinkBack Thread Tools Search this Thread
Old 01-13-2010, 05:25 PM   #1
Just wondering what it would take to convert a 2007 tacoma Prerunner 4.0 Ext cab with the TRD package to a 4 wheel drive.
dirtrider278 is offline   Reply With Quote
Old 01-13-2010, 06:17 PM   #2
eric-the-red's Avatar
Transfer case, both driveshafts, front diff and CV shafts, front hubs and the ecus for the 4wd and maybe the ABS. And probably more money than it would be worth. Cheaper and easier to sell it and buy a 4wd one.
eric-the-red is offline   Reply With Quote
Old 01-13-2010, 08:21 PM   #3
neoworm0's Avatar
It's actually pretty simple.
Two step process:
1. Sell 2wd
2. Buy 4wd
Done!
neoworm0 is offline   Reply With Quote
Old 01-13-2010, 08:22 PM   #4
haha no can do, love my truck. hmm are the prerunners any good at offroading if they have good tires?
Old 01-13-2010, 08:26 PM   #5
MaK92-4RnR's Avatar
best thing you can do is throw a locker in the back... even then you wont perform like a 4wd can. shoulda bought a 4wd dude.
MaK92-4RnR is offline   Reply With Quote
Old 01-22-2010, 08:41 AM   #6
Bobcat Sig's Avatar
Yah ... what they said. You may love your truck now. But if you buy the same truck with the 4wd underpinnings, you'll still love it. Sell the WeeRunner and get a 4wd.
Bobcat Sig is offline   Reply With Quote
Old 01-23-2010, 05:39 AM   #7
It can be done with a lot of labor and time and if you have the money.
And you may be able to do it fairly cheap if you can get what you need out of a wrecked truck.
The installation of the major components shouldn't be all that hard. After all, I think the front suspension is the same except for springs, since the fronts on the 4wd should have a higher rate (stiffer). The hubs and spindles should bolt right up. The transmission should be the same except for the transfer case adapter and mount.
While you are at it, you could go ahead and install a lift. New gears would be nice too, since you could do it while the front differential is out of the truck.
The problem would be knowing what's compatible with the electronics and electrical system. You would probably have to swap the wiring harness, and that would probably be a major task to do right. And by doing it right, that means not damaging the harness you need to install during the installation, and routing it the right way so it doesn't get damaged later on while driving. It would mean working in very tight areas and removing a bunch of components.
Then what would you do for a warranty?
And when you go to trade it, they will try to give you what the PreRunner is worth, not what a 4wd is worth. Maybe less, since the truck has been extensively modified.
After you add up the downtime and cost of alternate transportation, the cost of parts, the cost of any damage due to screw ups during installation, the major amount of time involved, it's just not worth it.
I would trade it on a 4wd that's got about the same miles or less as your truck. You can get a good extended warranty. And if you haggle enough, you may be able to get away with not paying much more than you are paying now.
And it would certainly save you major time, money, and headache.
William is offline   Reply With Quote
Old 01-23-2010, 09:30 AM   #8
whokrz's Avatar
Quote:
2wd can go offroad. When I was a kid we took a full sized ford van hunting all the time and went down some pretty bad roads. I also saw a 2wd ford ranger at red lake in Sierra National Forest http://www.gentryoffroad.com/php/tra...hv/whokrz2008/ He had a modified clutch, rear locker and 33" mud tires (aired down). He said that he made it all the way to the lake without being pulled, which I find a little hard to believe.
My point is with good tires / slight mods a 2wd will go a lot of places if you know how to drive. I would also recommend taking recovery gear with you and know that 2wds have trouble going backwards uphill.
Personally a prerunner is a nice truck and I would keep it on the street.
When most people start driving off road they always want to push the vehicle just a little bit further all the time. I would recommend buying an older 4wd 22re toyota for cheap. That way when you beat it up you will not care nearly as much.
whokrz is offline   Reply With Quote
Old 03-29-2011, 10:30 AM   #9
sl0annuggets's Avatar
I wouldnt bother unless it was a low mileage 01-04 double cab and I had a lot of time
sl0annuggets is offline   Reply With Quote
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
Which Toyota do I have Cplmike Newbie Tech Section 5 07-08-2015 09:47 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
2nd gen with runner cage Steezy96yota 86-95 Trucks & 4Runners (Build-Up Section) 1 07-06-2015 11:00 AM
back of cab body plugs (1991 sr5) elwood73 86-95 Trucks & 4Runners 0 07-05-2015 08:07 AM
Tags
06, 4x4, adapter, case, convert, drive, give, package, prerunner, tacoma, toyota, transfer, trd, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
