| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
VSC TRAC lights on, no codes come up
#2 (permalink) |
I have a 04 runner myself and had the Same problem. Did some research and I kept getting to check the gas cap to see if it was closed tightly, which was not the best answer in my situation. So then after taking my truck into Toyota they said it was one of the four Oxygen sensors gone bad, got that replaced and the light was gone for about 3 weeks,then once again the light appeared. I brought her in and after hours of waiting they told me they were sure it was the whole cat. , so luckily warranty covered that. To this day I havent had that light and its been about 4 months and also drove her to Mexico and back =D. Hope this helps a little
#3 (permalink) | |
Quote:
#4 (permalink) |
Got the new tires on. Look and feel great. Lights still on. Noticed when I slow down, one tire has a wobble. When I got home I checked all four tires, tugging on them. I found the passenger front tire has some give and makes a clunk when I grab the top and wiggle it. Any guesses? I think maybe a bearing.
#5 (permalink) |
OK. I just got done with basically the same problem. VSC and TRAC OFF along with the ABS lights came on. Battery was getting ready to crap the bed, and local guru's suggest that this might be the cause of the fault. NO CODES thrown by the OBDII.
Replaced the battery and lights stayed on, even after a week and a half of restarts. So... I figure this must be something simple, right? All of the wheel sensors appear to be OK. Wires are as new! I notice that the ABS System has relays and fuses up the arse in the relay panel, so I meticulously un-plug and re-plug all the relays and fuses associated with ABS. Hop in the car, fire it up. SHAZZAM!!! No lights. So I figure if this was a wheel sensor connection, it will probably show up again soon. If it was just a poor connection in the relay panel, then I may not see it ever again. Old school prodding and poking maybe just saved me a $400 trip to the dealer! |
#6 (permalink) |
I'm trying to revive a dead thread, but I had a similar experience with TRAC light staying on. I read this thread and was ready to go to battle in trying fix the issue!! Luckily, in my case it was just the gas cap not being tightened all the way upon last fill up (thnx wifey!!). I learned a valuable lesson, always check for the simplest explaination first, then take from there!!
I'm NOT trying to revive a dead thread>>> |
#7 (permalink) |
gofast- welcom to YT! Glad you got your issue settled. No worries about bringing back a dead thread...if it was 5 years old maybe but not this one
#8 (permalink) |
I've noticed the same phenomenon, I submitted a post in this URL:
http://www.yotatech.com/f2/trac-off-...d-help-186991/ Its not a dead thread for me, I'm trying to charge head on. Bmackey, what fuses did you pull, i'm willing to give it a try too! Last edited by drfeelgood824; 09-05-2009 at 06:26 AM. |
#9 (permalink) |
Good luck on your endevour!! The only thing I can suggest is try the simplest solution first. Hopefully it's something simple.
#10 (permalink) |
Just to clarify gofast, Ive done my research and read through all the threads i can find before i started this one and none helped solve my problem. Thanks for the suggestion drfeelgood, the recalibration makes sense, and is one i have'nt tried yet. Ill see if it works.
#11 (permalink) |
Thank you very much for the link drfeelgood. I checked it out and followed the instructions. It worked first try and cost me nothing. You saved me from getting ripped off at the dealership, which was my next option. I really apperciate all of you taking the time to reply.
Joe |
| Tags |
| 2004, 4runner, check, code, codes, engine, gx470, light, lights, sport, toyota, trac, track, truck, vsc |
