Need help with 4.0 TACO engine replacement
Old 03-05-2014, 07:35 AM
sharrack's Avatar
2007 tacoma/ auto/4wd/ 4dr
My buddy overheated his taco and the engine gases are leaking into the coolant system......the cylinder is drivers side, front cylinder.
The truck actually runs pretty well but he is thinking of replacing the engine.
2,400 for 90,000 salvage yard replacement engine /'keeps his engine to resell.
My question is how much do you think his old engine is worth in parts or as a whole with documentation of it running etc.
240,000 miles
Thanks.
Kenny
Old 03-05-2014, 07:51 AM
Fossilized
Staff
dropzone's Avatar
It leaks and needs a rebuild..sounds like it is worth core prices..
Old 05-14-2014, 10:44 AM
doitright's Avatar
240,000 miles
Thanks.
Kenny
So... his engine needs a head gasket, and he instead wants to spend thousands to buy and install a replacement engine?
Brilliant.
Old 05-14-2014, 02:35 PM
250000_yota's Avatar
Brilliant.
That's what I'm getting out of it.
If I were him, I'd do a head gasket job. Why replace your motor when you can just fix the issue?
Old 06-02-2014, 10:11 AM
vandert's Avatar
Well, aluminium + heat = need the head is possibly warped as well but definately I would rebuild in this case as well!
voiddweller
19
05-02-2016 09:10 PM
Vargntucson
07-04-2015 12:15 PM
merc1100sc
06-26-2015 05:24 PM
mick l
06-21-2015 09:27 AM
Toyota Punk
07-01-2002 05:44 PM
Quick Reply: Need help with 4.0 TACO engine replacement
