My 4Runner Jack isn't tall enough - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-13-2009, 10:40 PM   #1 (permalink)
Hey all!
I was jacking up my Runner's front tire with the Toyota supplied jack and placed it where it said to place it but the jack runs out of height before lifting the tire to be replaced. It needs like another 1" to 1.25" of height. The rear is fine since it's under the axle. Am I missing something here or is Toyota missing some height on their jacks?
s-one is offline
Old 07-14-2009, 01:06 PM   #2 (permalink)
If your tires are stock size, it should (just barely) have enough hight. Keep turning the handle and see if you can get that extra inch.
Will_4R is offline
Old 07-14-2009, 01:10 PM   #3 (permalink)
Yep everything is stock and my the jack is maxed out. It's weird because in the manual, the jack placement is exactly where it's suppose to be. I think Toyota goofed here but odd that its not commonly mentioned. I mean, the stocker guys.
s-one is offline
Old 07-14-2009, 01:50 PM   #4 (permalink)
Staff
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
i've used the stock bottle jack to lift my tire off the ground before... and its a 35.... is there any room under the lower control arm? that way your not fighting the suspension flex?
__________________
94 4runenr: all the good stuff.......
89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs.
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s
pacific-crawlers.com
For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :)
Tofer is offline
Old 07-14-2009, 02:06 PM   #5 (permalink)
twitchee2's Avatar
Send a message via AIM to twitchee2
i dont think your jack is maxed at that point. it should be as long as the top part.
__________________
-Eric
2002 SR5 4WD
Goodyear Wrangler Duratrac 265/75/16C
Deck plate + ISR
OME 881/890
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims
twitchee2 is offline
Old 07-14-2009, 02:21 PM   #6 (permalink)
That jack doesn't look maxed out to me. I say that you should have at least another inch of travel. Worse case scenario is put a brick or 2x4 under it to get it off the ground.
Before all of the hate mail comes this way, use this method only in an emergency and never work under a vehicle that isn't fully supported by quality jack stands that are rated more than the vehicle you are working on. Also, I would recommend getting a good jack to use for around the house. They don't cost much money and the are worth every penny.
ramtime is offline
Old 07-14-2009, 05:25 PM   #7 (permalink)
eric-the-red's Avatar
On my 01 the jacking point is under the cross member just behind where you're jacking, maybe try there. Or just get a 6" piece of 2x6 and put it under the jack
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 07-14-2009, 07:43 PM   #8 (permalink)
Seriously, this thing was maxed. I couldn't crank it a mm more. Someone else mentioned that crossmember so that'll do the trick for emergencies. Thanks guys!
s-one is offline
Old 07-14-2009, 08:02 PM   #9 (permalink)
twitchee2's Avatar
try taking it off and cranking it without weight. im 99.99999% positive you have at least anther inch on that thing.
__________________
-Eric
2002 SR5 4WD
Deck plate + ISR
OME 881/890
Old 07-14-2009, 08:25 PM   #10 (permalink)
scuba's Avatar
Doh !!
Try another spot..
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 07-14-2009, 08:27 PM   #11 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
i just go under the axle's
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 07-15-2009, 11:23 AM   #12 (permalink)
On the front, I jack on the control arm.
M1911 is offline
Old 08-10-2009, 08:10 AM   #13 (permalink)
Matt16's Avatar
Under the control arm or place scrap wood under the jack ie a foot of 2x6
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 08-10-2009, 08:17 AM   #14 (permalink)
The Ruckus's Avatar
Just experienced the same thing last week. It's not tall enough to do what it needs to under the cross member, exactly for the reason mentioned: suspension sag. My solution was close to the others suggested. One time I just cranked it to max then set it down on a jackstand, then moved the jack to the control arm- the other time I just used two jacks (and a jackstand as a backup).
__________________
2000 4Runner Ltd - 150k on body, 100k on motor
ISR/Deckplate mods
sans-running boards
Stillen/magnaflow exhaust
otherwise stock
The Ruckus is offline
Tags
1999, 2007, 48, 4eunner, 4runner, inch, jack, jacking, kit, lifting, points, put, spot, suv, tall, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
