| Home | Photo Gallery | Register | All Albums | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Search this Thread |
#1 (permalink) |
Low tire pressure light
My wife's 04 4Runner has a light on the dash that indicates low tire pressure.Problem is it keeps coming on.1st time was about a week and a half ago I checked tires & they were down to 30psi(should be 32)so I added air went to dealer & they reset the computer.Now today it's on again & the pressure is good(between 31&32) so I'm off to the dealer again.Any Ideas as to why this keeps happening?The Runner only has 2900 miles on it we haven't even changed the oil for the first time & I've made 2 trips to the dealer.
__________________
2003 Tacoma 4x4 Extra-cab ARB/Ramsey REP8000E Fabtech Basic lift(set at 2.5") 32" BFGoodrich A/T KO on 15x10 black rockcrawlers Lock-Rite Locker Radio Shack CB |
| Sponsored Links |
#2 (permalink) |
That's the problem with dohickeys...More things to go wrong. You shouldn't be worried, it's still under warranty. Just take it to the dealer and tell them to fix the darn thing.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home. '95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck. |
#3 (permalink) |
Sponsoring Member
Check the SPARE as it has a sensor in it as well.
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
#4 (permalink) |
yea I know Dohickeys & all the bells & whistles are nice but your right more crap to go wrong.That's why I boght my Tacoma w/o all that extra BS.The problem with the dealer is it takes a while to get there.The wife can't drive a 5 speed so she can't drive my truck so I have to drop her off at work,just a pita.
__________________
#5 (permalink) |
ive gotta say, thats a cool combo... 03 taco & 04 runner
#6 (permalink) | |
Quote:
__________________
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
I had the same thing happen to my 04 runner. the dealer said that the sensor codes in the tires were not the same codes that were programmed into the computer so they had to take the tires off get the codes reprogram the computer with the right codes and the remount and balance all of the tires including the spare. all under warranty
Problem happened at 1500 miles and i am now at 5,000 and it has not happened since. i did kinda find it weird that the pressure light did not go off till 1500 seems like it should have gone off sooner if there was a problem with the codes but oh well if it is fixed i don't care. hope this helps |
#9 (permalink) |
That sounds right Eli because I thnk she does have a tire upgrade to 17" wheels.Thanks I'll mention that when I bring it in.
__________________
#10 (permalink) |
on a side note... what happens to those that have this feature and go offroading and deflate the tire to say 12-15psi? does the pesky light stay on during that time?!?! just wondering
![]() Hope it all works out though... seems like a common problem of the 04's... btw, check out the other toyota forum (t4r.org) as I've read numerous times about this problem... just never affected me so i never read into it.. They might have some interesting knowledge that might help ya if what Eli tells ya don't work out. Good luck!
__________________
2003 4runner SR5 4x4 Chaos Edition Chaos Edition! Operation Rebuild Chaos Edition Need to reach me or ask questions? You can find me here! |
#11 (permalink) |
Tire pressure sensors......My god, what next
soon they will have sensors that tell you when your stomach pressure is to high & its about to relieve its self.
__________________
Maddog no 4x4 at this time Formerly > 1990 Hilux Surf (4runner) ssr ltd 3.0 V6,auto,31"s,140k km's. |
#12 (permalink) |
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#13 (permalink) |
That's hilarious
A full page write-up on how to check your tire pressure I wonder what size the book is that they wrote on how to start and drive your vehicle to get over to the air pump?BTW, "92 Toyota", it would probably be a good idea to get your oil changed right away as I've heard that there is alot of contaminants released during the initial 1000 miles, or so, due to engine break in etc. Just a suggestion.
__________________
'98 4Runner, SR5, V-6, 5-speed, 285 Revo's, E-Locker, 3" Susp Lift, 3" Body Lift, Elbow mod, Deckplate Mod, "D" gasket mod, Silverstars, Headlight Film, 67" TG Sliders, Relocated Oil Filter... Next on the list: 4:88 gears & 35's |
#14 (permalink) |
Swede,
That is a good idea about the oil change I was waiting until 3000 as the dealer has a sticker on the window saying next service at 5000 miles. Waskilly, You were right it was the spare I double checked with a better gauge when the wife got home from work today,sure enough it was down to 25psi.
__________________
#15 (permalink) | |
Sponsoring Member
Quote:
BEEN THERE, DONE THAT! ![]() Glad you got it figured out!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tire pressure warning light problem? | highway74 | 03+ 4Runner/GX470, & 05+ Tacomas | 10 | 04-13-2007 08:15 AM |
| How do you fix the low tire pressure light? | BIGTEX | 03+ 4Runner/GX470, & 05+ Tacomas | 15 | 10-28-2006 10:07 AM |
| 4th Gen Low Tire Pressure Warning Light | niseguy | 03+ 4Runner/GX470, & 05+ Tacomas | 7 | 10-14-2004 07:21 AM |
| 4th Gen. Low Tire Pressure Sensor question | Lookin' | 03+ 4Runner/GX470, & 05+ Tacomas | 9 | 10-12-2004 04:17 PM |
| Low tire pressure warning light | niseguy | 03+ 4Runner/GX470, & 05+ Tacomas | 0 | 02-22-2004 09:45 AM |
