How to disable VSC/TRAC on 4th Gen? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 01-08-2005, 10:54 AM   #1 (permalink)
yabedude's Avatar
Has anyone managed to install a switch that will disable the Vehicle Stability Control (VSC) and/or Traction Control (TRAC)? When offroading in snow or muddy conditions, the system wants to apply the brakes (ABS) when the wheels begin to spin. Many times, I want to be able to spin and keep momentum to get out of the nasty condition rather than be forced to slow and stop in the middle of it. I'm hoping that there is a wiring bypass switch that can allow me to temporarily disable the feature(s) on demand.
__________________
--Chris
2003 4Runner 4x4 4664 cc
This was the Sport model, but hardly any more :)
yabedude is offline
Sponsored Links
To remove this ad, register today!
Old 01-08-2005, 11:21 AM   #2 (permalink)
While not about the 4th Gen, please read this to see where we are with the same issue on the late model 3rd Gens.
Andreas
__________________
2001 SR5 4Runner 4WD, Dorado Gold, 153,XXX miles
2007 Volvo XC 90 AWD V6, Silver
1995 Porsche 993, Polar Silver
aowRS is offline
Old 01-08-2005, 12:36 PM   #3 (permalink)
mypalthetortoise's Avatar
I thought locking the center diff turned the VSC off?
mypalthetortoise is offline
Old 01-08-2005, 12:44 PM   #4 (permalink)
yabedude's Avatar
That's correct. The center diff locking button does turn off the VSC. However, TRAC is still enabled. TRAC will apply ABS when a wheel is spinning. The other thread http://www.yotatech.com/showthread.php?t=45793 is on the right track (no pun intended).
__________________
--Chris
yabedude is offline
Old 01-08-2005, 01:19 PM   #5 (permalink)
DealMaker's Avatar
To add to the TRAC confusion, I saw a small muddy field parking lot today and decided to check it out. With my center diff open, the TRAC kicked in almost immediately as I went into the field. Then a bit later, I locked the center, and proceeded to spin the tires and slid around a bit, and shot mud everywhere. It didn't seem that the TRAC kicked in at all. I was in 4H the whole time. Perhaps the TRAC disengages in 4H but activates again in 4L when the center is locked??
__________________
'04 4Runner 4X4 SE V8
BFG KO 265/70/17 - Donahoe Coilovers - Deaver rear springs - Bilstein 7100 shocks - Hanna Sliders - Shrockworks Front Bullbar
DealMaker is offline
Old 01-08-2005, 01:31 PM   #6 (permalink)
FirstToy's Avatar
Send a message via Yahoo to FirstToy
4th gen has GEN II ATRAC. imo, it's a really nice setup, I like it alot. It's amazing what it can do.
I've had the same experience as RBLA w/ the CDLocked.
__________________
Owned YT-style
Quote:
Originally Posted by pullnshoot25
just out of curiosity, are there any women on this forum? Just curious to see if there are some serious wheeling women out there.
Quote:
Originally Posted by calrockx
eharmony.com not working out for ya?
FirstToy is offline
Old 01-08-2005, 02:28 PM   #7 (permalink)
bulldog-yota's Avatar
VSC is disabled when you lock the center diff. The reason you dont like VSC is that it throttles back when it senses a lot of wheelspin, thus killing momentum. (ask me I got stuck badly ona sand dune because of this). When you lock the center diff TRAC still works in both 4H and 4L, however once you rev beyond 3500RPM (or somewhere close) TRAC turns off to prevent damage to the driveline. Imagine full throttle at high RPM and it grabs a brake and sends all the power to the other wheel. TRAC only sense the wheelspeed difference between wheels on the same axle, so if both are spinning at the same speed it will be happy. That is the reason why guys can put lockers on it with no ill effect, VSC however will create problems with lockers as it senses a whole lot of variables and acts accordingly.
So for snow, mud, sand, etc lock the center diff and you will be fine. WHen you feel the TRAC kicking in it actually just helps to maintain your momentum.
__________________
___________________
*****andries*****
03 Pavement Princess
05 Mall Queen
bulldog-yota is offline
Old 01-08-2005, 03:04 PM   #8 (permalink)
FirstToy's Avatar
hmm, really good description Andries! I must refer to it in the future.
__________________
Owned YT-style
FirstToy is offline
Old 01-08-2005, 06:05 PM   #9 (permalink)
yabedude's Avatar
Today, I confirmed the claims that high RPMs will effectively disable TRAC. However, high RPM's on a slippery snowy road is not for me. 3500 RPM's is a lot in the V8 and would be extremely unsafe on a tight road with rocks, trees, and major cliffs within arms reach. Need to find a way to kill TRAC on demand.
__________________
--Chris
yabedude is offline
Old 01-08-2005, 06:16 PM   #10 (permalink)
DealMaker's Avatar
Quote:
Originally Posted by yabedude
... However, high RPM's on a slippery snowy road is not for me. 3500 RPM's is a lot in the V8 and would be extremely unsafe on a tight road with rocks, trees, and major cliffs within arms reach. Need to find a way to kill TRAC on demand.
for slippery snowy roads you may just want to use cable chains, like these that I just bought the other day..
http://www.scc-chain.com/Pages%20Tra...ucts/szlt.html
size ZT-741
__________________
Old 01-08-2005, 10:13 PM   #11 (permalink)
FirstToy's Avatar
yabedude,
I guess I'm having a hard time understanding why you want to disable trac when going slow... not doubting your driving abilities or anything but am a little confused.
I ran some icey trails up in Big Bear last year and the trac was very good for those situations. Wheelspin= loss of control. I want traction, thus control.
For higher speed stuff, like the dunes Andries mentioned, it is transparent with the CDL... you can leave the CDLocked for your entire trip offroad...
Not saying trac is perfect or anything but...? imo, seems pointless to try to disable it. Hope I'm not opening a can of worms but how is this going to help on the trail?
__________________
Owned YT-style
FirstToy is offline
Old 01-09-2005, 08:34 AM   #12 (permalink)
Yota-Reign's Avatar
Funny you mention high RPM's on a slippery snowy tight road w/major cliff w/in arms reach... I was on a nice single lane gravel road with a several hundred feet drop on one side a couple days ago... oh yeah, like you said with about a foot of snow. I had a couple miles of windy road to go before I got to the top of the mountain where there is a nice big area to turn around... Well not having anyone wheeling with me that day I decided I should stop since the elevation gain would probably bring on 6-12 more inches of snow before I got to the top. Single lane road=reverse for 1/2 mile. Well I slid over towards the mountain side into the ditch. OOPS! Much better than sliding the other way of course, that's why I was closer to the ditch than normal. Hmmm.. spun the wheels a little, not making much headway... got the front wheels at full lock towards the other side of the road... had to just step on it until I could feel the tires hook up and was able to get out without slingshotting across the road over the edge... I doubt that killing the TRAC would have helped me at all.
Sorry guys, I forgot my camera.
Lesson Learned: Don't go wheeling w/out someone to help you safely recover your vehicle, a winch on my vehicle would not have helped me that day.
__________________
04 4Runner Sport V8
Mods: TRD exhaust, Daystar lift, American Racing Diamondback 17x8 w/4.5" BS, BFG MT's 285/70-17, Surco Urban roof rack, HQ sliders, 4Crawler 1.25" BL
Yota-Reign is offline
Old 01-09-2005, 01:53 PM   #13 (permalink)
yabedude's Avatar
Quote:
Originally Posted by FirstToy
yabedude,
FirsToy: It's not a can of worms. My request is becoming more common. I agree that TRAC is good if you have momentum, but when you have no momentum and are trying to get momentum, there is little you can do. Maybe you've not been in a real sticky situation yet?
Find a nice slimy stretch of trail that has 2 ruts about 8-9" deep so that the belly of your rig is dragging. Make sure it just rained and that the trail is basically a cattle trail and caked with mud like the Indians used to make houses with. You do not want TRAC to kick in. You want all 4 wheels spinning to get you through that crap. Step outside the cabin and you'll be sinking up to your ankles in the . Been there, done that.
Only yesterday did I find out that high RPM's would have helped, but there are trails where I don't want to be driving like a maniac. It's too risky in some environments.
No, I want to have a switch to disable TRAC on demand so that I can maintain a constant wheel spin and not have to be spinning my wheels at 50 miles per hour.
__________________
--Chris
yabedude is offline
Old 01-09-2005, 02:53 PM   #14 (permalink)
FirstToy's Avatar
I've been in the muck... it hasn't been an issue for me. It seems like maybe you are not in 4Lo at the time? 3000rpms is not hard to reach in 4Lo at all...
I totally don't get it but I'll just leave it at that. - and not to criticize what you're doing at all- hope you find a fix for your dilemma.
__________________
Owned YT-style
FirstToy is offline
Old 01-09-2005, 03:27 PM   #15 (permalink)
I don't get it either.
You can't have front & rear lockers, since they don't make em yet... Why would you want no TRAC, it's the only thing to keep you in control of the truck?
I mean, yeah, you're right, it would be nice to have an on/off switch, but if you're following what Ducky's doing in that other thread, it ain't going to be plug & play.
Old 01-09-2005, 04:00 PM   #16 (permalink)
FirstToy's Avatar
ARB makes a rear locker and front will be coming soon. Good Times (aka, Dialup boy) is running a ARB rr locker for a while.
__________________
Owned YT-style
FirstToy is offline
Old 01-09-2005, 04:36 PM   #17 (permalink)
I'm aware Lance is running a rear locker, but he is a rare breed. For 99% of the 4th gen public, though, TRAC actually keeps the wheels spinning controllably (like a limited slip differential does).
I don't want to discourage anyone from trying to turn off traction control; it's just not necessary or beneficial... IMO.
Remember, also, if you disable VSC, TRAC and any of the other "safety" features if your truck, you're the one who is inevitably responsible in the event of a crash/ injury.
Old 01-09-2005, 04:43 PM   #18 (permalink)
FirstToy's Avatar
Quote:
just clarifying your statement, that's all.
trac/vsc won't be affected by installing ff/rr lockers (trac wont activate while locked but unlocked you will still have trac/vsc)
__________________
Owned YT-style
FirstToy is offline
Old 01-10-2005, 12:05 AM   #19 (permalink)
