| Home | Photo Gallery | Register | All Albums | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Search this Thread |
#1 (permalink) |
High Idle
I have a 2006 Tacoma prerunner. It sounds like it is idled high to me. It jumps to around 1200-1300 then drops to around 950. I brought it to the toyota place near me and they siad it had carbon build up and needed spark plug changes. They did this work and nothing changed. Can someone tell me if this is normal on the tacomas and what is the normal range for RPM's. I appriciate any help. Thanks
| Sponsored Links |
#2 (permalink) |
mine is doing the same thing and from what I was told there suppose to idle between 800-900 RPM but when its cold its normal to idle about 1200-1300 RPM but you can also check the plaque on the underside of your hood it tells you... I was told the same thing about my plugs/wires so Im gonna try it cuz mine are original from dealer and have over 223,000 miles on them
__________________
Trail Rig 81 Toyota 4x4: 22R, weber carb, L45 4 speed, 4.10 gears, 2" shackle lift F&R + 2" front springs, 31x10.5x15 ATs Daily Driver 84 Toyota 4x4: 22R, stock carb, G52 5 speed, 4.10 gears, 235/75/15 ATs Last edited by 4x4YOTA; 02-05-2008 at 11:52 AM. |
#3 (permalink) |
did you get your idle fixed??
#4 (permalink) |
your idle will definately be high when cold. When the engine is cold the 02 sensor does not function, the catalyst is cold and the engine/ecm is not in closed loop. The purpose of the high idle when cold is to get the engine up to operating temp as quickly as possible. The engine will run more efficiently when warm and the emmisions will be dramatically reduced by rapidly heating the catalyst and o2 sensor. It should idle around 750 and 800 rpm's when hot.
#5 (permalink) |
yeah. my dads idles around 2000rpm when cold and 750 once warm
__________________
2000 4Runner 3RZ 4WD BFG 31x10.5 AT's, Black steelies, Bilsteins, Custom fog lights, Homemade exhaust, ISR mod, Drilled/slotted rotors, White LED gauges, Black Widow safari rack, Black headlights and corners, Pioneer head unit, Two 12" Jensens with Sony Xplod amp |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Outside temp effects my idle and a/c high idle. | Chuki | 86-95 Trucks & 4Runners | 2 | 07-23-2006 12:10 AM |
| High Idle?? | Keggo | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-08-2004 01:06 PM |
| Does low idle=more power & high idle=less? | Yoter | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-13-2004 06:11 PM |
| 22re: very high high idle, very low low idle | mike_d | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 11-14-2003 07:50 AM |
| high idle | Churnd | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-15-2002 10:58 AM |
