Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 05-23-2007, 05:36 PM   #1 (permalink)
Exclamation Help - Problem w/ Revtek Lift - ABS, VSC, VSC-OFF LIGHTS
Help! I bought a Revtek 3" suspension lift (part #431) and had it installed professionaly at a shop but now have problems. My 4runner is a 2004 SR5, 2WD. Immediately after the lift was installed, the VSC, VSC OFF, and ABS lights lit up on the dash (no check engine light). They plugged in thier computer reader thing and it said there is a sensor error at the right front tire and a ABS malfunction. The shop checked the sensors but they swear everything is working properly. Anyone else have a similar issue or anyone know what to do.
Already tried disconnecting battery, reseting error, pulling FCU (or whatever it is) fuse.
Please help!
clarky_007 is offline
Sponsored Links
To remove this ad, register today!
Old 05-23-2007, 10:32 PM   #2 (permalink)
Expat's Avatar
They may not have been careful with the ABS sensor wire when installing your spacers. In this case they probably damaged the wiring. You must be very careful about the ABS wire not to stretch it. I'd almost guarentee you this is what is happening.
__________________
Mark
04 4Runner SE,275x70x17 MTR's, Shrockworks Bullbar, Shrockworks Rock Sliders, 1.5" 4Crawler Body Lift, Kurt trailing Arms, OME Suspension, MagnaFlow muffler, 60" High Lift Jack, Yaesu FT-7800 Ham Radio, Diamond Magnetic Mount Antenna, Cobra 75WX ST CB radio, Wilson 5000 Antenna, Sirius Satellite Radio, Garmin iQue GPS, On-board CO2 system.
Expat is offline
Old 05-24-2007, 06:52 AM   #3 (permalink)
i agree
i came with'n seconds of doing that very thing
when i was trying to get clearance for my OME lift
it's way tight in there and hard to notice every detail
__________________
2003 SR5 4runner 4x4 V6 Ti-Silver
bought new still bone stock
5/4/07
OME 884/n140s 895/142
265/70/ r17 Mickey Thompson MTZ
LEADfoot is offline
Old 05-24-2007, 10:26 AM   #4 (permalink)
mac4runner's Avatar
I agree with the previous two posts. Been there, done that. Replace the ABS sensor wire and your problem will be solved.
__________________
2004 T4R SR5 V8
SAW COs (F) - OME 895 & N141 (R) / Hanna Sliders / 265/70-17 Nitto Terra Grapplers / Scion w/ XM / Garmin Nuvi 760
mac4runner is offline
Old 05-24-2007, 11:57 AM   #5 (permalink)
Thanks for the responses. The sensor is already on order so hopefully that will fix the problem.
Old 08-19-2008, 01:24 PM   #6 (permalink)
any one know how much the abs sensor wire cost????
coconut is offline
Old 08-19-2008, 01:25 PM   #7 (permalink)
cost of abs sensor wire??
coconut is offline
Old 08-20-2008, 12:07 PM   #8 (permalink)
mac4runner's Avatar
If memory serves, it's about $60.
__________________
2004 T4R SR5 V8
Old 08-20-2008, 09:39 PM   #9 (permalink)
ksu1998's Avatar
You lower a Lexus or lift a 4runner...same result. Watch those ABS sensor cables...
__________________
97' SR5 212K Remote start/alarm, WAAG front bar, Hella 500's, Yak rack, Bridgestone REVOS, Cobra CB/PA, Pioneer AVIC D3, JL/fosgate
03' G35c 32K Brembo, navi, MT
01' QX4 80K SOLD found out it was no 4runner
ksu1998 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
vsc,trac,abs lights are on TSLBOGGGER 95.5-2004 Tacomas & 96-2002 4Runners 15 01-30-2007 06:09 AM
VSC lights, ABS lights, No Front Brake Info after Lift Edrake 03+ 4Runner/GX470, & 05+ Tacomas 1 12-08-2006 03:48 PM
TRAC OFF, VSC TRAC, ABS lights on mini_fly 95.5-2004 Tacomas & 96-2002 4Runners 15 05-12-2006 05:58 PM
VSC off, VSC Trac and CEL came on after putting in K & N Air Intake HenrySacto 95.5-2004 Tacomas & 96-2002 4Runners 9 12-30-2005 02:16 PM
04 4-runner Transmisssion VSC Trac VSC off lights freemanc 95.5-2004 Tacomas & 96-2002 4Runners 8 03-10-2005 10:57 AM
2009 InternetBrands, Inc.
