| Home | Photo Gallery | Register | All Albums | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Search this Thread |
#1 (permalink) |
Senior Member
help me understand this 4th gen "multi mode 4wd" crap
OK... we've had my wife's 4th gen 4Runner for about a month now, and we got our first real snow storm last night. All these new fangled switches, dials, and idiot lights have me confused.
What ever happened to good old manual locking hubs? Or at least a mechanical shifter for a true transfer case? Oh, that's right... the soccer mom revolution... OK, anyways... how about shedding some light on this multi-mode 4wd business for me? I went to put it in 4wd last night but there are like 3 settings that all seem to be 4wd, and different lights flash for each setting. so... 2hi and center diff unlocked - traditional rear wheel drive? 2hi and center diff locked - ??? 4hi and center diff unlocked - ??? 4hi and center diff locked - traditional 4wd? 4lo and center diff unlocked - is this even possible?? 4lo and center diff locked - traditional 4lo? The manual is about worthless... I assume flashing lights mean that the whatever (transfer case, diff, whatever) isn't engaged/locked yet? It's an 04 if it matters. *sigh* I miss manual hubs...
__________________
Jackson - My Site 96 SR5 4x4 - 33" MTs, open diffs, and 3.90s - LET'S ROCK! My runner has bee traded in *sniff* on an 06 SR5 long bed d-cab Tacoma. The tacoma is nice, but... *sniff* ... I'll update my site when I'm done grieving. Last edited by jacksonpt; 03-01-2005 at 11:13 AM. |
| Sponsored Links |
#2 (permalink) |
Location: Ocean Beach, CA Five square miles surrounded by reality.
i can offer this much...
2 hi=rear wheel drive 4 hi with center dif unlocked=all wheel drive, safe for dry pavement. 4 hi with center dif locked=traditional 4 wheel drive as far as 4 low goes...i dont know why you'd need 4lo with the center dif unlocked. with the center dif locked it basically transfers 50% of the power to the front dif and 50% to the rear dif. with it unlocked (i think) it basically acts like an open dif, transfers the power to the front or rear difs based on which needs more power (someone correct me if i'm wrong about this). i usually use 4 hi with the center dif unlocked for snow/ ice/ heavy rain when i'm on road, and use 4 hi with the center dif locked for dirt/ mud off road. edit: in 2 hi the center dif doesnt do anything. if you try to lock it it will just flash the warning light, but it doesnt really change anything.
__________________
'02 4Runner 4WD/ 4" deckplate mod/ ISR mod/ Tundra brake upgrade/ Stubbs Welding t-case skidplate/ 32" BFG A-T's/ Satoshi grille Last edited by potsy; 03-01-2005 at 11:20 AM. |
#3 (permalink) | |
Senior Member
Quote:
__________________
Jackson - My Site 96 SR5 4x4 - 33" MTs, open diffs, and 3.90s - LET'S ROCK! My runner has bee traded in *sniff* on an 06 SR5 long bed d-cab Tacoma. The tacoma is nice, but... *sniff* ... I'll update my site when I'm done grieving. |
#4 (permalink) |
AWD is better in slippery conditions anyday over 4wd since true 4wd doesn't stop spinning until you let off the throttle. I drove my AWD Eclipse around for 7 mountain winters and definetly has a more secure feeling than my Runner does but anything over 8 inches of snow then it had problems.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#5 (permalink) | ||
Quote:
Quote:
__________________
-Scott '01 Black SR5 4x4 w/ Black Pearl's: Detroit Truetrac | Tundra/OME 890s w/ Tokico Trekmasters | SS Diff Drop/Panhard | Tundra rotors/calipers | Rear Diff Breather Extension | Hayden cooler | K&N | ISR | Deckplate | Jet Black PC'd LC 16x8's w/ LT265/75R16 Cooper S/T's "He who wants to protect everything, protects nothing." -Lt. Gen. Adolf Galland, Luftwaffe "There is no instance of a country having benefited from prolonged warfare." -Sun Tzu, The Art of War Last edited by hillbilly; 03-01-2005 at 11:43 AM. |
#6 (permalink) | |
Senior Member
Quote:
But perhaps I don't have enough experience with good AWD systems... I just know I hate driving my wife's BMW in the winter for that reason.
__________________
#7 (permalink) |
Senior Member
ok... I get it now - thanks all.
__________________
#8 (permalink) | |
Quote:
As far as 4Hi with the diff. unlocked, it will be a bit like an AWD with the exception that it doesn't have a computer monitoring the slipage of each individual wheel like a good Full-Time AWD system does. Still better for the snow than a traditional 4WD though. Hope this helps!
__________________
- Kevin '99 4Runner SR5 - Green - 115,000+ miles Rear locker, 265/75/16 BFG AT's, and custom sliders to be added soon! |
#9 (permalink) | |
Quote:
If I ever move anywhere that gets snow, a Subaru will most likely be in our garage (hopefully a WRX)
#10 (permalink) |
Yes,some of the newer AWD systems incorporate too much computer control but the system used in the 1st and 2nd gen DSMs worked very nicely and allowed you to make the power input and steering but never allowed the rear end come. Subaru and Mitsubishi have a few new goodies on their newer systems but they still allow alot of driver feel and control.
I used to take a backway through a state park close to my house every time we got 4-10" of snow just to play in my Eclipse since there's nothing like "drifting" through a whole corner with the rear kicked out and the front tires still controlling the nose.
__________________
#11 (permalink) | |
Quote:
__________________
#12 (permalink) |
yeah, i used to own a subaru myself, the thing was awesome in the snow...thats alot of the reason i got a 4runner instead of a tacoma...the availablity of the awd function of the 4wd system. as far as i know only the 4runner and jeep grand cherokee have full-time 4wd (awd).
__________________
'02 4Runner 4WD/ 4" deckplate mod/ ISR mod/ Tundra brake upgrade/ Stubbs Welding t-case skidplate/ 32" BFG A-T's/ Satoshi grille |
#13 (permalink) | |
Quote:
__________________
89 4runner SR5 22RE BIFUEL-LPG conversion, BFG M/T OME lift |
#14 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| multi mode 4x4? | kenai | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 02-25-2007 10:06 PM |
| ecu "safe mode" question | punkbek3886 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 12-06-2005 05:22 PM |
| max speed when in AWD (multi-mode 4WD) | KZN185W | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 10-01-2005 08:28 PM |
| 4th Gen Surefire light "mod" | Woodbert | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 10-27-2003 04:42 AM |
