| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Help connecting the flywheel to the torque converter
#2 (permalink) |
__________________
2003 4runner SR5 4x4 Chaos Edition Chaos Edition! Operation Rebuild Chaos Edition Need to reach me or ask questions? You can find me here! |
#3 (permalink) |
it is probably just a longer bolt to help pull the converter in to get the rest of the bolts started. if the converter is pushed in all the way into the bellhousing properly. the regular bolts might not reach the converter, thus the helpful longer bolt. it shouldn't matter which hole you use it on. don't listen to me though. i have no experience with these year models, that is just my edumacated guess from the experience that i do have.
__________________
-89 deluxe 4runner 22re/A340H -85 extended cab 4x4 with 22r/G52 -89 corolla 4af |
#4 (permalink) |
I agree with toyaholic
#5 (permalink) | |
Quote:
It shouldn't matter, the bolt pattern should be equally spaced. Just make sure the converter is seated all the way into the front of the trans before you mount the trans bellhousing to the engine. If installed properly, when the bellhousing is mated to the engine, the converter bolt studs should come thru the flexplate, but not be bound up. You should be able to wiggle the bolt studs in the flexplate holes before installing the nuts. If it isn't free to move a little, pull the trans back out, and try reseating the converter again.
__________________
TechWrench If it ain't broke, fix it till it is. ---------------------------------- '03 SR5 V6, Titanium, 275/70-16 REVO's on '02 OEM alloys for winter. Anti-chipmunk mod for fresh air intake. |
#6 (permalink) |
i am having this same problem, i think my torque converter is not seating all the way in. It's somehow getting stuck. do i need to be in gear, or park? is there some kind of trick installing the torque converter to an auto transmition bell housing in the truck. The engine is removed. I'd much rather not remove the trans from the truck. Is this possible? or an i just going about this the wrong way?
87 4Runner rebuilt 22RE IFS Last edited by aquamato; 10-09-2006 at 04:00 PM. |
#7 (permalink) | |
Quote:
PS; I just re-read your post, and now realize the trans is still in the truck, and the engine is out. My method of installing the converter is still the same, you will just have to climb into the engine compartment to do it. Just remember, lift and turn at the same time to get the converter to drop into place. When dropping the engine into the truck and up to the trans, the principle is still the same. You should use guide pins to help line the engine and trans up. If you are installing the engine while the truck is on the ground, you will probably need a friend to help line up the converter studs to the flexplate from below while the engine is mating to the trans. I would also use a jack under the trans pan to raise the front of the trans up to help with lining everything up.
__________________
TechWrench If it ain't broke, fix it till it is. ---------------------------------- '03 SR5 V6, Titanium, 275/70-16 REVO's on '02 OEM alloys for winter. Anti-chipmunk mod for fresh air intake. Last edited by TechWrench; 10-18-2006 at 10:48 PM. |
#8 (permalink) |
to seat the torque converter properly, i usually just spinin 1 direction(20-30rev) and keep pressure on it and all the gears will lock into place. havent tried on 4runner AT, but on another toyota works fine.
if it is in place, the torque converter will go in very far. itll seem weird at first but thats what the long bolt is there for. not seating in properly will cause catastrophic result, and my neighbor have seen one being put in not properly. btw, id recommend replacing the torque converter input seal while youre at it.
__________________
Tran, oO 4runner - Millenium Silver WTB: 01-02 4runner right(pass.) taillight .,~??▼.,~??▼.,~??▼ WTB: Hood wind deflector Last edited by profuse007; 10-19-2006 at 11:40 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| What is the 3VZE Connecting rod bolt torque spec | ars 28-701.2 | 86-95 Trucks & 4Runners | 3 | 05-21-2007 06:58 PM |
| Could this be the torque converter? | Del | General Vehicle Related Topics (Non Year Related) | 1 | 01-01-2006 03:17 PM |
| 22re flywheel torque specs? | Dr.Feelgood | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 09-11-2005 10:05 PM |
| Lining up torque converter with flywheel for bolt install | naksukow | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-11-2005 09:28 PM |
| flywheel torque, and clutch face direction on 3.slow | Eric | Maintenance & Repair Archives | 3 | 04-08-2005 08:18 PM |
