GX-470 folks...what year did VVTi start ?? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 04-11-2007, 11:24 AM   #1 (permalink)
nrgetic99's Avatar
I am familar with the 4runner and when it switched to VVTi (I had an 03 V8 runner and had my bubble burst the first time I drove a VVti)
Is there a model year/date cut off for VVTi in the GX-470 as I am now in the market for a used one.
Regards
David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Sponsored Links
To remove this ad, register today!
Old 04-13-2007, 11:29 AM   #2 (permalink)
profuse007's Avatar
first time hearing a toyota owner concerns w/ VVT-i.
thats the 2UZ-FE w/ VVT-i on 04+ GX470 and 05+ 4runner.
i dont think the vvt-i on those motors are there for performance, its there for lower emission.
__________________
Tran,
oO 4runner - Millenium Silver
WTB: 01-02 4runner right(pass.) taillight .,~??▼.,~??▼.,~??▼
WTB: Hood wind deflector
profuse007 is offline
Old 05-07-2007, 07:33 AM   #3 (permalink)
nrgetic99's Avatar
I may have worded my post badly. The evident lack of low end torque on my non VVTi V8 was painfully evident after driving them back to back.
Emmisions of not, the peak power increases by 40 hp and the torque curve is flattened and peak torque is lower which is significant in terms of driveability.
David
__________________
Old 05-07-2007, 10:40 AM   #4 (permalink)
JohnD's Avatar
its totally a performance upgrade, it improves torque thru out the rpm band, lower emission is just a side benefit, wait to they start offering full vvt-i. you'll get the benefit on the exhaust side as well. vvt-i-L. available on most celica gts and matrixs xrs as well as a few lexus models is & gs models.
If im not mistaken its was 2000 they started using that cam setup on toyota's, lexus im not so sure.
peace
__________________
05runner v8 4x4,DR coilovers&UCA's frt&Rr,shrock works bullbar,dual battery kit, Goodyear wrangler 275/70/17's,K&N cold air intake,frt & tranny skid.!
the420th.com
JohnD is offline
Old 05-07-2007, 11:43 AM   #5 (permalink)
BT17R's Avatar
IIRC, the VVT-i also improved EPA ratings slightly. Great choice for a used SUV. New and loaded they went for over $70K. A clean, low mileage '04 lease turn-in will go for half that. Also, take the VIN to a Lexus dealer and they'll give you the service and warranty history if the owner used a Lexus dealer.
__________________
'07 FJ Cruiser TRD SE 6M/T All Black
BT17R is offline
Old 05-08-2007, 11:19 AM   #6 (permalink)
nrgetic99's Avatar
Quote:
Thanks great info !
David
__________________
Old 05-14-2007, 10:08 AM   #7 (permalink)
ProMed's Avatar
The GX470 received the VVT-i treatment in 2005 at the same time as the T4R.
ProMed is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
can you swap a lexus 470 axle in a 2nd gen 4runner bballchrism Solid Axle Swaps, All Years 8 04-26-2007 12:09 AM
TJM T-3 on a lexus GX will it fit? Spectre 03+ 4Runner/GX470, & 05+ Tacomas 13 02-14-2006 09:59 PM
Electronic speedo, what year did they start? Joyota 95.5-2004 Tacomas & 96-2002 4Runners 6 03-15-2005 12:18 PM
New VVTi for 2005 Hannerhan 95.5-2004 Tacomas & 96-2002 4Runners 13 08-24-2004 06:23 AM
2009 InternetBrands, Inc.
