Clunk in rear suspension? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-28-2006, 07:27 AM   #1 (permalink)
Lookin''s Avatar
Hi All,
Somewhat frequently I get a clunk from the rear of my 04 4R. It happens after I come to a somewhat fast stop and when I release the brakes to go again. It feels like someone just bumped me from behind. Has anyone else had this problem?
Dave
__________________
04 Sport V6 4X4 Galactic Gray
MODS:
T&H Center Grill Guard
Hella FF-75 on Grill Guard (tight fit!)
30% Tint
K&N filter
SilverStar H/L/F
Hanna Quality sliders (Nice!)
Lookin' is offline
Old 02-28-2006, 01:25 PM   #2 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
You're expeciting axle wrap/wind-up. It happens when the rear driveshaft skip joint binds up. If you stop abruptly, the rear axle will rotate down a little and the driveshaft slip joint will open up slightly and then stick in place. When you release the brake and accelerate, the shift in vehicle position will cause the slip joint to "jump" back in place giving you the "thud" feel/sound.
If you lube the slip joints 99% of the time, the problem will get resolved. Some other alternatives is to take it into Toyota but all they'll do is lube and call it a day.
Btw this has been covered as it's a very common issue for many of us. Search for some of the key words and you'll definitely find a lot of details on this issue.
Good luck
Good Times is offline
Old 03-01-2006, 06:43 AM   #3 (permalink)
Lookin''s Avatar
Thanks Good Times--- Since I posted I did find what you have told me. I never did find a definitive answer on the grade of grease to use though. Does it matter?
__________________
MODS:
30% Tint
K&N filter
SilverStar H/L/F
Lookin' is offline
Old 03-07-2006, 07:24 AM   #4 (permalink)
Lookin''s Avatar
Thanks to all.... a little grease and all is well! What a simple fix for something I thought was going to be a battle with the stealer. Thanks...
__________________
MODS:
30% Tint
K&N filter
SilverStar H/L/F
Lookin' is offline
Old 03-19-2006, 06:14 PM   #5 (permalink)
I was experiencing the same problem in my 98 when I first bought it 2 months ago. I was told from some Yotatech faithfuls that I needed to lube the driveline and U-joints and the problem was fixed thereafter. I too was expecting the worst, but thank God it was as easy as shooting some grease in the Runner. I believe if you do a search on this site you can find a pretty detailed write up on where to lube and what lube to buy. Good luck.
__________________
1998 4runner SR5: K&N FIPK II, Manik Brush Guard, Brembo rotors.
98runn'n is offline
Old 03-19-2006, 06:26 PM   #6 (permalink)
it is in the maintenance subform in the tech section. and as far as what grease to use, look in the back of your manual in the "specifications" section.
noobs, take some time and look around in the tech section. there are some really good writeups in there. note that searching *may not* always pull up a writeup, depending on the key words you use. thus, look in the tech section
bob
Bob_98SR5 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Clunk in rear when braking FrmrJPGuy 95.5-2004 Tacomas & 96-2002 4Runners 18 10-24-2007 08:53 AM
clunk, clunk, clunk noise from front left wheel in 79 4x4 .faded.fedor. General Vehicle Related Topics (Non Year Related) 2 04-02-2007 09:14 AM
Panhard Rod Making Noise - Clunk Clunk Mojo_Risin 95.5-2004 Tacomas & 96-2002 4Runners 32 03-21-2007 06:53 PM
rear suspension clunk tombothetominator 86-95 Trucks & 4Runners 2 12-03-2006 10:28 PM
Clunk from rear hatch area? 4Runnerman 95.5-2004 Tacomas & 96-2002 4Runners 7 12-16-2003 07:10 AM
2009 InternetBrands, Inc.
