YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-23-2008, 09:53 AM   #1 (permalink)
andrewmitch's Avatar
CB's and Scanners
If anyone has installed a CB or Scanner in your Runner where did you put it?
In my old car I was able to sneak the scanner under the radio and burried in the dash (where the CD option would have gone). This allowed me to hard wire the power and antenna and to hide it from the LEO's as it is not legal in every state. But the Runner doesn't seem to have any space like at all???
__________________
Andrew from Connecticut
2005 4Runner SR5 V8, 5-Speed Auto, All Wheel Drive, 17" Rims, Black/Grey
After Market:
*K40 Radar/Laser Detector/Diffuser Front & Rear (built in).
*Python GPS Stolen Device Tracker.
*Parrot Hands-Free Cell Kit.
*Back Up Sensors.
*Tinted Windows.
*Security Box inside center console and bolted to frame.
*Nokian WR Tires (265/70/17)
2005 4Runner SR5 V8 AWD
andrewmitch is offline
Sponsored Links
To remove this ad, register today!
Old 07-23-2008, 10:02 AM   #2 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
did you search? there are alot of threads on this.
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 190,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
年のトヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 07-23-2008, 01:41 PM   #3 (permalink)
olharleyman's Avatar
I put my GALAXY 99 on the glove box but it is a lot bigger then most of the radios guys are using here size wise and power wise also have a TEXAS STAR 450 watt linier with it.
I belive the CORBRA 19 will fit under the stereo with a bit of trimming just check the posts on CB INSTALLS AND YOU FIND THE RIGHT MODEL for installing under the stereo
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift Kit custom 6" coils rear
lock right #1620 Rear
Aussie Locker #xd-27527 front
5.29's Front And Rear
35 x 12.5 x 15 B.F.Goodrich KO's Micky Thompson Classic II Wheels
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
Streached 5.5 gal. tanks
16" Ape Hangers
3" open primary
"Three People Can Keep A Secret If Two Peolpe Are Dead"
Benjamin Franklin
olharleyman is online now
Old 07-23-2008, 02:35 PM   #4 (permalink)
did you kills the little storage space below the radio?
(yes i searched but come up empty)
__________________
After Market:
*Back Up Sensors.
*Tinted Windows.
Old 07-23-2008, 03:29 PM   #5 (permalink)
pepsibluefloat's Avatar
Send a message via AIM to pepsibluefloat Send a message via MSN to pepsibluefloat Send a message via Yahoo to pepsibluefloat
i put mine in that space under the radio. fit perfectly. needed no trimming or anything.
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|35" Goodyear MT/R
My 4runner n stuff
pepsibluefloat is offline
Old 07-24-2008, 02:57 AM   #6 (permalink)
PepsiBlueFloat - what space under the radio? Do you mean you removed the small little compartment? There seems to be very little space there?
I was thinking about using the area where the electric outlet is. It seems to be wide enough I just have to see if there is room below it (ie to go deeper). I like this configuration because there is a nice little cover that I could use to hide the scanner....
__________________
After Market:
*Back Up Sensors.
*Tinted Windows.
Old 07-26-2008, 09:02 AM   #7 (permalink)
In the comparment under the stereo and climate control and where the little storage compartment is - does anyone know how far back that goes? I have a scanner that is 8 Wide by 7 DEEP by 2 High....Ideally, I'd like to keep the cover over it too to keep it hidden....
__________________
After Market:
*Back Up Sensors.
*Tinted Windows.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Where do you get CB's tuned?! SC4Runner GPS & Communication 4 04-23-2006 03:27 PM
Police Scanners data Off Topic Talk 14 04-09-2005 06:49 PM
Police Scanners pigcake Off Topic Talk 16 01-09-2005 06:28 AM
CB and scanners Good Times 95.5-2004 Tacomas & 96-2002 4Runners 9 07-24-2003 07:47 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
